Accenture Solutions Co Ltd
Posted: Aug 29, 2018
Last activity: Sep 2, 2018
Last activity: 2 Sep 2018 2:02 EDT
Operator IDs
I have to create 200 operators for an application.Is there is any utility to do so in shortest time.
Also, What should fall under consideration if I update it from database in pr_operator - table?
PFB some consideration.
- Operator IDs should end with @xxx.com
- For example in this case Operator ID should be - [email protected]
- Once Operator ID is created, it should be assigned to the access group - CAMSSecurity:SysArch
- Operators should able to login and validate the above USER ID
