Add Operator Dynamically
I want to add a menu in pycasemangerlinks that helps to add a new operator. How to proceed with it?
For creating new operator id record, Pega provides default activity called as 'AddNewOperatorRecord'. But when you run the activity it shows Org,Div,Unit errors after filling the form. So, you have to include the pyOrganization, pyOrgDiv, pyOrgUnit as params and set the values by using property set method in the activity.
Please find the attached snippets for more details.
Abhishek Goel
Hi Aditya,
You can also check pzCreateOperator activity which can be configured to be run on click of the button in your portal.
Here also you need to pass all the values in the activity as a parameter. Below are parameters used in this activity:
Vikash
