Nordea
SE
Last activity: 28 Aug 2018 9:12 EDT
Check Data Integrity via BIX
We are using pega 7.1.9 and with the help of BIX we are generating XML file of work objects and the same file is being transferred to different system for some data analysis.
We have received a new requirement to ensure the data integrity of the XML and check if the data which is being transported as part of XML and the one stored in Pega database is same. I know BIX exports the same data what he have in the database but Unfortunately I couldn't find any OOTB wayout to prove this.
One possible solution I can see is using File listener which can read all the exported XML files and then compare the content from database.
Could someone suggest any alternate way?
