Assigned to BrokenProcesses to ' Repair flow configuration '.
Hi all.
I have an application with 2 cases.
The cases are very simple, only a Flow with a Robot Queue assignation.
The flows working correctly, the work is assigned to correct workbasket, the automation is execute and robot manager return "Completed".
But, in the "Audit" of Assignment detail, I have this error only for ONE of 2 flows:
"Assigned to BrokenProcesses to ' Repair flow configuration '."
This prevents me from adding new stages to the flow, because the flow it stops at the same point.
I tried to add a new case, but the situation is the same.
The only flow that works correctly is in the first case I created.
Can you help me?
Marco
