Aaseya IT Service Pvt Ltd
Last activity: 21 Nov 2019 2:17 EST
Case dependency going to repair flow
We have requirement in a way that the flow parent case cannot move to resolve stage unless the child case is resolved. This seems to be working fine in dev but there are sometimes errors in PROD environement . The parent goes to repair assignment and keeps sitting on wait shape.
Following is the error on parent case : .pxInsName: Keys of Instance Value must be specified
Since this scenario is not frequent and reporducing in DEV, not able to guess the issue. Please suggest solution to fix/debug.
BPM Company
What's your actual solution, could you provide screenshots?
attached screenshot
BPM Company
Is it happening then AFTER you complete the child case? or during?
Once child case is resolved, the parent case goes to repair flow and gets stuck in wait shape
BPM Company
But can you still see the case ID on the top of the screen? the pxInsName contains the id in the format WO-24.
Yes i can see case id and pxInsname has the value
FR
Have you tried to double check your log files? At that specific time can you see any specific error?
No new exceptions in logs were found
FR
What PRPC version is it? Maybe you could use the AddCoveredWork activity instead of CreateWorkPage activity can you?
We are in 8.1.0 version. I am using the smart shape to created child case. Can you give me reason behind changing the pxAddChildWork which is OOTB to above activity. Since this issue is not reporducible in DEV.
FR
Well,
Of course I'm not recommending to apply that change directly in Production. It is always difficult to work on a configuration when you have nothing to replicate and test against.
I've seen such issue generated in the past due to those activities. Could you trace in Production? Have you seen any patterns like mainly the same user having this issue or maybe passivation occuring?
FR
