The Bank of Nova Scotia
Last activity: 31 May 2018 15:58 EDT
Error when register VM(Robot) - InternalServerError(500)
We currently installed pega platform 7.3.1 personal edition with Robot Manager version 4
I am receiving the following error msg when register bot, and runtime will shutdown.
Registering Robot - Name: 'TESTWVAPPI01474', Queue: 'Online Maintanence', Auth Mode: ServerAuthenticationMode.
Failed to register Robot - Name: 'TESTWVAPPI01474', Queue: 'Online Maintanence'
Error requesting data from Pega. http://myhost.com/prweb/PRRestService/robotics/v1/register
Code: InternalServerError(500), Content: System.Threading.Tasks.Task`1[System.String]
RoboticsService.RegisterRobot - Failed to register robot.
RPA mode is enabled, but robot failed to register. Runtime will shutdown.
I believe everything has been set up correctly. if you have any idea for this issue will be great appreciate
***Edited by Moderator Marissa to update categories; update SR Details***
Vaishnavi Ramesh -
Learning
Hello ,
Kindly check the below link for your reference:-
Hope this helps.
Hari
Hi Chalh,
I already tried this method... it does not work
Brian
The error definitely suggests that there is a configuration issue on the Pega Platform side. The most common item for people to miss is the Decision Table, pyGetAccessGroupForRobotByWorkGroup.
Can you provide screenshots of your access groups on the operator id that is set to register your bots? Also the work tab of the operator id.
Hi Mitchell,
Thanks for help, attached all screenshots needed.
Prabu T
Hi Mitchell, sorry missed operator ID work tab screenshot, attached it in this reply
VINEETH KICHILU
You need to open an SR for this issue.
SR has been opened, SR-C30261
Thx
Thank you!
Hi @brianz14,
Upon reviewing the associated SR on this thread, it shows that the SR was withdrawn. Did you resolve this on your own?
Thank you!
