Freelancing
Last activity: 10 Jan 2022 4:45 EST
Default Pega API 7.2
Hi guys,
Need some assistance,
I am using the OOTB Pega API to create the Case
Request :
"caseTypeID": "ORT5RH-Fx-Work-CompanyInfo",
"processID": "pyStartCase",
"parentCaseID": "",
"content": {"AccountName": "user","LegalCompanyName": "com"}
Response :
"ID": "ORT5RH-FEDEX-WORK C-733",
"pxObjClass": "Pega-API-CaseManagement-Case"
Problem statement : when I open the Case created Eg: C-733 there is no page pxFlow. any configuration we need to follow ?
Updated: 10 Jan 2022 4:45 EST
Freelancing
Hi Asif,
Thanks for the response, above issue was on some instance reason was not known, now its working fine.
Senario 2 :
I tried this on the cloud space provided by pega i was able to create the case using the pega OOTB API.
Same think i tried hitting the request URL from 3rd party app call POSTMAN, i am getting status 304 NOT Modified.
Any think i need to to case when doing on cloud ? This is because i need to try this in cloud in realtime application as well.
URL : -
Method :- Post
Request :
"caseTypeID": "TGB-HRApps-Work-Learning",
"parentCaseID": "",
"content": {
"FirstName": "sample text",
"Location": "sample text",
Response : 304 Status.
Authentication used : Basic authentication
please find the attachment.
Chandan U
EPAM Systems, Inc.
ES
Your JSON structures appear to be fine, could you verify it once. Navigate to Resource->Pega API.
Try POST /cases Create a new case. Check the response message.
Freelancing
Asif,
Thanks for the response , i tried the same above response is from Pega API its self. this happens some case type not all so i got this .
Chandan U
Freelancing
Hi Asif,
Senario 2 :
URL : -
Method :- Post
Request :
"parentCaseID": "",
"content": {
Chandan U
Hi Chandan,
No other configuration is needed.
Please share the tracer while work object creation(trace the rest service) and the case designer screenshots.
These would help isolate the issue.
Updated: 19 Jan 2018 8:59 EST
Freelancing
Hi Ravi,
Senario 2 :
URL : -
Method :- Post
Request :
"parentCaseID": "",
"content": {
Chandan U
JPMorgan Chase & Company
The request is processed successfully please check once, 304 response is to minimize information transfer when the recipient already has one or more cached representations, a sender SHOULD NOT generate representation metadata other than the above listed fields unless said metadata exists for the purpose of guiding cache updates.
