BBX
CN
Last activity: 2 Feb 2018 6:57 EST
Unable to launch modal flow action in portal
BBX
CN
Hi Rachit,
thank you very much for answer my question.
This problem has been solved, the method is to create a DataPage, Object type is XYZ-Demo-Work-CommonM, source is Data Transform.
I guess it should be no instance of XYZ-Demo-Work-CommonM .
Can you use OOTB Flow action ActionStab and try to launch it on click of the link ? What is the outcome ?
BBX
CN
All the rules in PEGA other than the one which you are creating are considered as OOTB rules. For example, the OOTB rule will generally belong to Ruleset starting with Pega or UI(for the user interface).
Also, Null pointer exception may come due to various reasons, we cannot be sure what is causing the issue unless we have the complete tracer of the use case.
So, as suggested earlier try to use ActionStub flow action and let us know the result.
Rachit
BBX
CN
BBX
CN
BBX
CN
BBX
CN
Hi DengC004,
Sorry for the delayed response.
Can you please remove the Page and Class parameters and see if it is working. If it does not please share the snapshot of your flow action.
Rachit
BBX
CN
Hi Deng,
Sorry for the delayed response. What I meant is in the local action - event you have configured on click you have given 2 parameters.
1) Using Page: CommonM
2)Class Name: XYZ-Demo-Work-CommonM.
These are not required parameters so can you try keeping them as blank and try your use case. Please let me know in case of further clarifications.
Rachit
BBX
CN
Hi Rachit,
Bukhari Saheb Shaik Wilhelm Mauch Premkanth Gudipati Trina Roy Gaurav Londhe
