Need to launch a modal window on launch of portal
We have a requirement that we need to launch a modal window the moment a user logs in. So can anyone tell how this can be achieved ?
Look up the function pega.u.d.attachOnload. Without knowing your exact use case, I can't really guide you any further, but this function will be part of your solution.
In addition, I believe the following article is on point:
https://collaborate.pega.com/question/how-subscribe-function-close-and-open-documentharness-multi-document-container
Hope this helps!
The requirement is that we need to open a pop-up/modal window then after user submits the pop-up/modal window, the window should get closed. This pop-up/modal window is required when portal is launched
