Verizon
Last activity: 10 Nov 2017 2:57 EST
Have to use Long datatype in Pega
I have a requirement to store "98888541236589" in Pega as a number. But this field exceed the Integer limit, therefore Pega throws an error. Kindly let me know, how to use Long data type in pega.
Hi
You can use "Phone" data type
Clipboard snapshot
Thank You
Verizon
Thanks for the response
Verizon
Hi Shekar
I couldnt find Phone Data type in Pega 7.1.6. Kindly advice.
I see "Phone" in 7.1.7, not sure about 7.1.6
Can you try using "Double" type
Thank You
But you need to cautious with the rounding precision as it allows the user to enter the floating number.
Hi, I am using 7.3 and I don't see any data type "Phone". I have a similar requirement.
This is available in the Cell Properties in the UI, you can open the properties of your property in the section then Click on Change link, then you can see Phone type in Inputs category.
Regards
Mahesh
You can create property as I have show below. These are done in 7.3
