How to use single database to setup for 7.1.7V and 7.2 environments.
I have created an instance with Pega 7.1.7 as Application server by on Oracle 11g as a database. Now I am trying to create new instance on separate machine Pega 7.2 as an Application server on existing database which were used for Pega 7.1.7. I created new connection in Database and table space user and grant access to the user and modified the context file and later I tried to run the setup.jar file and gave all the details accordingly and entered database details and checked the connectivity. It show status as good. But when Rulebase Load is failed to run.
error messages
BUILD FAILED
C:\Pega722\pegaGuInstallerTemp\build.xml:133: The following error occurred while executing this line:
C:\Pega722\pegaGuInstallerTemp\build.xml: 99: The following error occurred while executing this line:
C:\Pega722\scripts\setupDatabase.xml:471: The following error occurred while executing this line:
C:\Pega722\scripts\setupDatabase.xml:1426: Table 'pr4_base' already exists in the database. Please clean the schema and re-attempt instance
Total time: 21 seconds
Please suggest an approach how to resolve the error.
Vijay T
***Updated by moderator: Lochan to add Categories; remove personal information***
