Need Information about all new layout basic controls in section in 7.3
Hi Team,
Where i see information about every control under basic in section in 7.3
TLDR:
Grid, Tree, Tree Grid layouts from the older releases are renamed to Table, Hierarchical List, Hierarchical table respectively in Pega 7.3
Long form:
The question is phrased very ambiguously. It clubs layouts and controls and specifies a version. I'm guessing thats why we are seeing some confusion on the answers. I request that questions be asked more clearly going forward.
Reading between the lines and trying to guess what the question is, here is some info:
1. When authoring a section, we have three pallets in the tool bar, namely "Layout", "Basic" and "Advanced". The "Layout" pallet allows you to drag and drop different kinds of layouts. The other two pallets are related to configuring controls. Controls are categorized into "Basic" and "Advanced" and the two pallets correspond to them.
2. The "Layout" pallet's organization has undergone some change in 7.3 when compared to older versions.
3. The layouts are now organized into "Basic", "Row/List based", "Ajax based" layouts and older layout formats that are not recommended are organized under the "Legacy structures".
4. Grid, Tree, Tree Grid layouts from the older releases are renamed to Table, Hierarchical List, Hierarchical table respectively.
5. Information regarding layout authoring is present in Pega 7.3 help under Contents the contents tab: User interface > User interface rules > Harness and section forms
TLDR:
Long form:
6. AJAX based layouts classification groups two kinds of "layouts" which leverage AJAX and are somewhat different. An "Embedded section" is another section included in this section. And the dynamic container is something that you use in the portal harness. See help for more details.
Tree grid (or Hierarchical Table)
You can refer the below document
https://community.pega.com/sites/default/files/help_v73/procomhelpmain.htm
Thank You.
Hi Shubham,
I need information about new layouts like "Hierarchy layouts" ,Legacy , ajax etc
I did not find any specific document which gives complete details regarding Ajax bases Layout and Legacy layout.
But the layout in Ajax based are same as it was in pega 7 versions. Below link is about Dynamic container, you can refer that. https://community.pega.com/video-library/using-dynamic-containers
The Embedded section also looks like what it was in Pega 7 version named as Section inside layout
The Legacy layouts are those layouts which were supported previously by the application and you should mostly avoid using them in your newer application design. All of the legacy layouts comes with a warning and suggestion of using other new Dynamic or grid layout.
Regarding Hierarchical table refer the attachment.
I hope this helps.
Thank You.
Hi Shekar,
Thanks for your reply. Actually i am not aware of ajax layouts in Pega 7 lower versions. Can you please tell me what it is and how and when to use it.
I think what's new they have done in 7.3 version is they added these layout under the Ajax layout control, as there is no document I can't say if there has been any changes made for these two layout.
About Dynamic container, you can refer this link it should guide you more https://community.pega.com/video-library/using-dynamic-containers
As I told Embedded section also looks like what it was in Pega 7 version named as Section inside layout(refer the attachment). the section include is generally needed when you want to include any other section in your layout.
You can look into below discussion on section include
https://collaborate.pega.com/question/how-include-section-pagecontextuse-page-defined-property
https://collaborate.pega.com/question/refer-section-different-class-using-section-include
Again this looks same as it was in earlier version, so if there has been any change documents should be available soon.
Thank You.
Hi Shekar,
My last question was only about Ajax. I dint understand why did u share those links about embedding section and dynamic container.I am not even asking about Ajax in 7.3 , as u mentioned they(Ajax control) existed in lower versions , i want to know where i can see it, in which version and how to use it?
I think there was little misunderstanding.
When I said "But the layout in Ajax based are same as it was in pega 7 versions" I meant about Dynamic container and Embedded section which you are seeing in "Ajax based Layout" in pega 7.3 seems similar to Dynamic Container and Section in Pega 7 layout.
Now if you are asking about other Ajax feature in pega used either in pega 7.3 or previous version, I am not aware of those.
Thank You
Hello Pavani,
Hope below PDN link is useful to know what's new in 7.3.
https://collaborate.pega.com/discussion/achieving-continuous-project-delivery-using-pega-platform
Hi Shibani,
Thanks for sharing link but i could not find information about new layouts in UI. Can you please help.
TLDR:
Long form:
TLDR:
Long form:
Thanks a lot srinivas, this is what i was looking for.
