GovCIO
Last activity: 1 Aug 2017 12:19 EDT
Localization causing screen flickering issue across application - IE ONLY
As a part of our requirement, we have translated all the field values, paragraphs into Spanish language using Localization wizard. All the rule changes for these are in XYZRuleSet_es:01-01-01. The translation of rules are called properly while running the app by switching it from English with the help of a dropdown in the first screen. But the problem is like the screen is shaking or a kind of flickering I see when I select a option button or a check box or whatever the action taken on the field value's input. I am not sure on why I am seeing this sudden flickering in all the screens after localization functionality is implemented in QA/TEST env. Compared the application from STG environment without having this translation changes and I don't see this flickering. We are using PRPC V7.2.2 and is having 9 screens with 130 plus Spanish translation changes as per biz. Not sure on where I am getting wrong in this whole process. By the way, this issue is coming while entering the data and we are using Tabbed Screenflow for our application and we are good in Review harness. I tried in all possible ways to resolve this flickering issue but I couldn't. Can someone please help me on this?
Note:If this is related to product issue then I can create an SR for getting the HF/local change for it.
Ravi Kumar Pisupati.
***Edited by Moderator: Marissa to update categories***
***Edited by Moderator: Marissa to add SR Details***
