HCL
Last activity: 27 Jun 2017 9:07 EDT
Pega 7.2.2 Screen Alignment Issue
Our Application got Upgraded from 6.2 to 7.2.2 Post Upgrade one of our Screen Alignment was
messed up totally. Root Cause for this Alignment issue is due to "pzGridAction" section of
@baseclass in our Section. Regarding this I found similar article in PDN "https://community.pega.com/support/support-articles/pzgridaction-was-not-upgraded-properly"
but the Solution which pega mentioned it for 7.1.8 So will it be applicable for 7.2.2 as well?
Quick response for this question Appreciated and Thanks in Advance..
***Edited by moderator, Maryrita, moved to Product Support from Upgrade Center***
***Edited by Moderator: Marissa to update SR Details***
HCL
Will be good if we get response quickly for this Question Since above is one of the priority Issue..
Hello Vijay,
Thanks for posting your query in PSC :)
I am reviewing this and keep you posted with my observation at the earliest.
Rincy
HCL
Thanks for your reply RINCY we have raised SR already for this w.r.t Pega Support.
Hi Vijay,
Please share the SR number with us here so that we may tag it to your post above and track it to resolution!
Thank you,
HCL
Hi Lochan_Dv,
Sorry for Late reply SR-B54741 was raised w.r.t this issue and we got HFix-35122.
Thanks for letting us know Vijay! And the Hotfix resolved your issue?
HCL
Hi Marissa,
Yeah our issue got resolved after installing this Hotfix.
Vijay
That's great! Thanks for letting us know! I marked your reply with the Hotfix ID in it as the Correct Answer!
Hello Vijay,
As per the PDN Support Article, buttons are not displayed correctly, and cannot be clicked. Are you facing the same behavior in Pega 7.2.2? If yes, request you to raise a SR(Support Request) to get a HotFix for Pega 7.2.2. Hotfix shared on above Support article is meant for Pega 7.1.8 which cannot be used for Pega 7.2.2.
Rincy
HCL
Thanks Rincy we did same and got Hotfix for 7.2.2
