Localization of an Application
Could you please suggest me ways how to localize an application.
I have used localization wizard but haven't found all the necessary elements. For example, i didn't find "delete" column in the xml file and got AttachmentListView not fully translated.
Then, I've tried to do it manually by resaving section but it is an autogenerating section. There is only html code available and there is no way to find "delete" object in it.
Another problem is that resaving does not work with all the sections as long as those have plenty objects(i.e. properties, embedded section) that use a different ruleset.
Cheers
