MindTree Ltd
Reports Dashboard(pzRBCategoriesWrapper) not loading completely in IE
Hi, Need help on below issue.
Public categories (pzRBCategoriesWrapper7) section is not showing completely in IE. However the count is showing without any issue in Chrome browser.
I tired added below code in css in ‘py-case-manager-header-overrides/ py-responsive-overrides’- unfortunately, it is not working as expected. Please help me on this.
.two-col-main-sidebar > .content-item > .content-inner{overflow=visible}.
Is this reproducible using the OOTB administrator@pega login after launching the case manager portal and going to the report browser?
If so, hit F12 and take a screenshot of this for me. Like this.
MindTree Ltd
Hi Rett_Hean,
Here is the screenshot.
It looks like you may have some corporate/IT setting forcing your browser into an "IE10" mode. Can you please hit the emulation tab, and toggle it to "Edge" which is the IE11 default, and let me know if the issue goes away?
MindTree Ltd
Hi Rett, I tried with the given suggestion - unfortunately, the problem still remains same.
Thanks, Hari
Hi Hari,
I think this is going to require a live session to debug this. It might make sense to open an SR at this time.
Best Regards,
Rett
MindTree Ltd
Hi Rett, Thanks for your response. I opened SR for the same. Thanks, Hari
Hi Hari,
Could you please comment back with the SR # that you opened so that we may connect this thread to it to help out the Engineers?
Thanks in advance!
MindTree Ltd
Received the solution. Thank you all for your help
Hi Hari,
So glad to hear you found the solution. Do you mind sharing it here so that the rest of the Community may benefit in case they have the same issue?
Thanks!
OCBC
LK
Hi Hari,
Can you post the solution here?
I'm facing the same kind of issue.
Thank you in advance...
Thenuzan
