How to remove Report Defition Title from Chart Report in Dashboard
So i have a chart in dashboard. I have added title in chart but it shows Report Defition title too. How to remove the RD title from dashboard
@abdulr697 To remove the Report Definition title from the chart in your Pega dashboard, open the Report Definition used in the chart. Go to the "Chart" tab and make sure your custom chart title is set as needed. Then switch to the "Report Viewer" tab. In that tab, uncheck the option that says "Display report title" or "Show title on report" (the wording may vary slightly depending on your Pega version). Save the Report Definition after making this change. Now when you view the dashboard, only the chart title will appear, and the default Report Definition title will no longer be shown. This helps make the chart look cleaner and avoids repeating titles.
@Sairohith Tried that but not able to find the option to hide title in Report viewer tab
