MeBank
Last activity: 12 May 2017 0:56 EDT
[PEGA 7.1.9] Noticed random occurrences of the same SQLState HY008 error on the logs
Hi there,
We use PEGA 7.1.9 and noticed random occurrences of the same SQLState HY008 error on the logs.
This PDN article contradicts the JDBC driver connection string property documentations at the following places.
https://docs.microsoft.com/en-us/sql/connect/jdbc/setting-the-connection-properties?view=sql-server-ver15&viewFallbackFrom=sql-server-ver15%3Fview%3Dsql-server-ver15
https://docs.oracle.com/cd/E13157_01/wlevs/docs30/jdbc_drivers/mssqlserver.html
Should we raise a separate SR or is it advisable to go ahead with the accepted correct answer?
Jay
***Updated by moderator: Lochan to create new post from this reply***
Original Post: Getting DatabaseException : the Query has timed out, when trying to open any item from Data Explorer
If the query timeout are due to various queries, you may have to analyze them case by case. The one listed here is using UDF from a report, which is known to have performance issue (definitely never use UDF in production). You can avoid using UDF by exposing all the relevant columns in the report definition. Here are some guidelines from our internal performance experts:
The UDF’s primary value is for design time and unit testing. UDF usage is really discouraged in production.
We are not asking the customer to drop UDF’s per se but
- a- Do not use UDF’s in queries that run frequently
- b- Do not use UDF’s in queries that return many rows
- c- Never use UDF’s in a where clause.
In a development environment, at design Pega7 will not allow use of UDF in a where clause. You will get an error if you try to save a report definition that selects using a non-exposed property.
If you see a UDF in a where clause, that typically means that someone has moved a report definition into production without dependent schema changes and schemas are out of sync from dev to prod. We do not validate rules during migration.
All the property names should be case insensitive. The pdn article should be corrected. In your case, what app server are you using? Can you show your datasource definition and how the parameters are defined?
MeBank
Thanks Kevin.
We are running on JBOSS EAP 6.4 with Java 1.8
Below is our datasource definition.
Thanks Kevin.
<datasources>
<datasource jta="true" jndi-name="java:/jdbc/PegaRULES" pool-name="PegaRULES" enabled="true" use-ccm="true" statistics-enabled="false">
<connection-url>jdbc:sqlserver://peg_prd_agl01:1433;DatabaseName=PEGA_ProcessCommander;integratedSecurity=true;selectMethod=cursor;sendStringParametersAsUnicode=false</connection-url>
<driver>mssql</driver>
<pool>
<min-pool-size>30</min-pool-size>
<max-pool-size>100</max-pool-size>
</pool>
<validation>
<valid-connection-checker class-name="org.jboss.jca.adapters.jdbc.extensions.mssql.MSSQLValidConnectionChecker"/>
<validate-on-match>true</validate-on-match>
</validation>
<timeout>
<set-tx-query-timeout>false</set-tx-query-timeout>
<blocking-timeout-millis>0</blocking-timeout-millis>
<idle-timeout-minutes>0</idle-timeout-minutes>
<query-timeout>0</query-timeout>
<use-try-lock>0</use-try-lock>
<allocation-retry>0</allocation-retry>
<allocation-retry-wait-millis>0</allocation-retry-wait-millis>
</timeout>
<statement>
<prepared-statement-cache-size>100</prepared-statement-cache-size>
<share-prepared-statements>true</share-prepared-statements>
</statement>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="mssql" module="com.microsoft.sqlserver.jdbc">
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class>
</driver>
</drivers>
</datasources>
Jay
what jdbc driver jar are you using? You should use sqljdbc42.jar if not already for java 1.8. Also can u post the complete exception stack in your case?
Thilini Pramoda
MeBank
Sorry for the late reply. We are using sqljdbc42.jar with Java 8.
Below is a sample stack trace [attached as a txt file as well] that I could spot in the logs. It happens randomly for various queries.
2017-05-03 09:05:36,624 [] [TABTHREAD0] [ ] [ ] ( rd.queryexec.SqlQueryExecutor)
ERROR - An error occured on executing the query for the report definition - There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out.
com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out.
SQL: SELECT dbo.pr_read_from_stream('.pxCurrentStage', "PC0".pzInsKey, "PC0".pzPVStream) AS "pxCurrentStage" , "PC0".pxObjClass AS "pxObjClass", COUNT(dbo.pr_read_from_stream('.pxCurrentStage', "PC0".pzInsKey, "PC0".pzPVStream)) AS "pySummaryCount(1)" FROM dbo.MEB_COBRA_WORK "PC0" WHERE ( dbo.pr_read_from_stream('.pxCurrentStage', "PC0".pzInsKey, "PC0".pzPVStream) IS NOT NULL AND "PC0".pxObjClass = ? AND "PC0".pyStatusWork NOT LIKE ? ) GROUP BY dbo.pr_read_from_stream('.pxCurrentStage', "PC0".pzInsKey, "PC0".pzPVStream) , "PC0".pxObjClass ORDER BY 1 ASC, 2 ASC
SQL Inserts: <MEB-OPS-COBRA-Work> <Resolved%>
Caused by SQL Problems.
Problem #1, SQLState HY008, Error code 0: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out.
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6283)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:5979)
at com.pega.pegarules.data.internal.rd.queryexec.SqlQueryExecutor.executeQuery(SqlQueryExecutor.java:68)
at com.pega.pegarules.data.internal.rd.queryexec.SqlQueryExecutor.executeQuery(SqlQueryExecutor.java:43)
at com.pega.pegarules.data.internal.rd.SqlReportExecutor.executeQuery(SqlReportExecutor.java:284)
at com.pega.pegarules.data.internal.rd.SqlReportExecutor.executeMainReport(SqlReportExecutor.java:128)
at com.pega.pegarules.data.internal.rd.SqlReportExecutor.execute(SqlReportExecutor.java:90)
at com.pega.pegarules.data.internal.rd.SqlReportExecutor.execute(SqlReportExecutor.java:57)
at com.pega.pegarules.data.internal.PRDataProviderImpl.executeReport(PRDataProviderImpl.java:1229)
at com.pega.pegarules.session.internal.mgmt.Executable.executeReport(Executable.java:10829)
at com.pegarules.generated.definition.ra_action_pycountbystage_f73ad5082bf6aeb943ac3d7d9ac1b3be.perform(ra_action_pycountbystage_f73ad5082bf6aeb943ac3d7d9ac1b3be.java:50)
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3310)
at com.pegarules.generated.activity.ra_action_pxretrievereportdata_b344d5bdd6cbecf59bb8240bcd2b34c3.step30_circum0(ra_action_pxretrievereportdata_b344d5bdd6cbecf59bb8240bcd2b34c3.java:3418)
at com.pegarules.generated.activity.ra_action_pxretrievereportdata_b344d5bdd6cbecf59bb8240bcd2b34c3.perform(ra_action_pxretrievereportdata_b344d5bdd6cbecf59bb8240bcd2b34c3.java:637)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3505)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10563)
at com.pegarules.generated.activity.ra_action_pxcallretrievereportdata_ac7c5191bd54e9e32ee884ac93fa0a8e.step4_circum0(ra_action_pxcallretrievereportdata_ac7c5191bd54e9e32ee884ac93fa0a8e.java:373)
at com.pegarules.generated.activity.ra_action_pxcallretrievereportdata_ac7c5191bd54e9e32ee884ac93fa0a8e.perform(ra_action_pxcallretrievereportdata_ac7c5191bd54e9e32ee884ac93fa0a8e.java:123)
at com.pegarules.generated.activity.ra_action_pygetstagecountforcase_ef8296b9ae1ad0dddf0f888be11fcd66.step3_circum0(ra_action_pygetstagecountforcase_ef8296b9ae1ad0dddf0f888be11fcd66.java:387)
at com.pegarules.generated.activity.ra_action_pygetstagecountforcase_ef8296b9ae1ad0dddf0f888be11fcd66.perform(ra_action_pygetstagecountforcase_ef8296b9ae1ad0dddf0f888be11fcd66.java:103)
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runRule(DeclarativePageDirectoryImpl.java:994)
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runLoadActivity(DeclarativePageDirectoryImpl.java:452)
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.loadDataPage(ReadOnlyDataPageHandler.java:239)
at com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.findDataPage(ReadOnlyDataPageHandler.java:395)
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.findDataPageInCurrentDir(AbstractPageDirectory.java:920)
at com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.getDirectPage(AbstractPageDirectory.java:713)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDirectPage(ThreadPageDir.java:469)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:427)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:419)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getPage(PRThreadImpl.java:534)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2169)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.getTopPage(PropertyReferenceImpl.java:2113)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.resolveEmbeddedPages(PropertyReferenceImpl.java:1794)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1369)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1349)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.doGet(PropertyReferenceImpl.java:1333)
at com.pega.pegarules.data.internal.clipboard.PropertyReferenceImpl.get(PropertyReferenceImpl.java:1169)
at com.pega.pegarules.session.internal.mgmt.Executable.getProperty(Executable.java:2299)
at com.pegarules.generated.html_section.ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.simpleLayout_2(ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.java:423)
at com.pegarules.generated.html_section.ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.pzLayoutBodyWrapper_2(ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.java:319)
at com.pegarules.generated.html_section.ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.pzLayout_2(ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.java:513)
at com.pegarules.generated.html_section.ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.pzSectionBody_1(ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.java:253)
at com.pegarules.generated.html_section.ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.execute(ra_stream_pxdisplaystagesreport_e651746cdb0d436ca3a7f43382a63789.java:100)
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:717)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.getStream(IncludeStreamRuntime.java:332)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.emitIncludeStreamReference(IncludeStreamRuntime.java:252)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.emitIncludeStreamReference(AutoStreamRuntimeImpl.java:358)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.sectionBodyIncludeInCell_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:545)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.simpleLayoutCell_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:566)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.simpleLayout_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:590)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.pzLayoutBodyWrapper_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:507)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.pzLayout_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:603)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.simpleLayoutCell_2(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:625)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.simpleLayout_3(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:673)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.pzLayoutBodyWrapper_3(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:373)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.pzLayout_3(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:687)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.pzSectionBody_1(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:225)
at com.pegarules.generated.html_section.ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.execute(ra_stream_pydashboardmiddle_695c4510cbc3100585b0f26a563bcc09.java:100)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.sectionBodyIncludeInCell_1(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:378)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.simpleLayoutCell_1(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:399)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.simpleLayout_1(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:423)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.pzLayoutBodyWrapper_3(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:340)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.pzLayout_3(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:436)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.simpleLayoutCell_2(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:458)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.simpleLayout_3(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:506)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.pzLayoutBodyWrapper_5(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:234)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.pzLayout_5(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:520)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.pzSectionBody_1(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:223)
at com.pegarules.generated.html_section.ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.execute(ra_stream_pyportalpageheader_3715d9f8fe75a748de77b7e3ff0640cf.java:100)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:4038)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuleRuntime.getSectionStream(AutoStreamRuleRuntime.java:149)
at com.pegarules.generated.html_section.ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.includeSectionBody_1(ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.java:234)
at com.pegarules.generated.html_section.ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.pzLayoutBodyWrapper_1(ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.java:223)
at com.pegarules.generated.html_section.ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.pzLayout_1(ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.java:239)
at com.pegarules.generated.html_section.ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.pzSectionBody_1(ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.java:212)
at com.pegarules.generated.html_section.ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.execute(ra_stream_pydashboard7_f9bce75f003f7e54682b798f94090fc8.java:100)
at com.pegarules.generated.html_harness.ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.includeSectionBody_1(ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.java:3038)
at com.pegarules.generated.html_harness.ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.generatePegaHarnessDiv_6(ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.java:1852)
at com.pegarules.generated.html_harness.ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.execute(ra_stream_pydashboard7_562b53626bb8a6eff448fcca3fa430a5.java:699)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3866)
at com.pegarules.generated.activity.ra_action_displayharnesswithclass_4cc9f9e9cb9b892dd9c83273e3c08a6c.step4_circum0(ra_action_displayharnesswithclass_4cc9f9e9cb9b892dd9c83273e3c08a6c.java:495)
at com.pegarules.generated.activity.ra_action_displayharnesswithclass_4cc9f9e9cb9b892dd9c83273e3c08a6c.perform(ra_action_displayharnesswithclass_4cc9f9e9cb9b892dd9c83273e3c08a6c.java:120)
at com.pegarules.generated.activity.ra_action_uiactiondisplayharness_e25153649f09cc31b4c450da2335ba4c.step8_circum0(ra_action_uiactiondisplayharness_e25153649f09cc31b4c450da2335ba4c.java:765)
at com.pegarules.generated.activity.ra_action_uiactiondisplayharness_e25153649f09cc31b4c450da2335ba4c.perform(ra_action_uiactiondisplayharness_e25153649f09cc31b4c450da2335ba4c.java:198)
at com.pegarules.generated.activity.ra_action_douiaction_b1b5bac99d191ebf335be422b0d3ab71.step18_circum0(ra_action_douiaction_b1b5bac99d191ebf335be422b0d3ab71.java:1868)
at com.pegarules.generated.activity.ra_action_douiaction_b1b5bac99d191ebf335be422b0d3ab71.perform(ra_action_douiaction_b1b5bac99d191ebf335be422b0d3ab71.java:355)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:461)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3358)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:385)
at sun.reflect.GeneratedMethodAccessor59.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:852)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:240)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:734)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:847)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:295)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:214)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:231)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:149)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:420)
at org.jboss.as.web.security.SecurityContextAssociationValve.invoke(SecurityContextAssociationValve.java:169)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:150)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:97)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:102)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:344)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:854)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:653)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:926)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The query has timed out.
at com.microsoft.sqlserver.jdbc.TDSCommand.checkForInterrupt(IOBuffer.java:7727)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:78)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1650)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:440)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:385)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7505)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2444)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:191)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:166)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.execute(SQLServerPreparedStatement.java:367)
at org.jboss.jca.adapters.jdbc.CachedPreparedStatement.execute(CachedPreparedStatement.java:296)
at org.jboss.jca.adapters.jdbc.WrappedPreparedStatement.execute(WrappedPreparedStatement.java:404)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:581)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6202)
... 144 more
MeBank
It looks like we have to check quite a few places for UDFs :-). Thanks for taking time to clarify this.
