Pega Proactive Notice: Thread Locking
- Pega 8.1
- Pega 8.1.1
- Pega 8.1.2
- Pega 8.1.3
- Pega 8.1.4
- Pega 8.1.5
- Pega 8.2
- Pega 8.2.1
- Pega 8.2.2
Are there any Proactive Notices Avaible for 7.x Series (especially after 7.3.x) or 7.4.x, thanks!
There are not, nor are there plans to do so in the future. However, we did recently do a community collaboration to catalog all 7.x critical hot fixes. This provides a single reference for 7.x installs to ensure they are current with the hot fixes Pega has deemed critical for secure and performant deployments.
Thank you Brendan. 7.x Link you have provided doesnt have any HFix's mentioned for 7.3.1 or Higher Versions, can I assume,no Critical HFIXs avaiable for those PRPC Versions or the Page not updated?
Let me check into this before providing a definitive response. For now I can tell you that there were none listed at the time we posted this initial draft. It wasn't too long ago, and we do have a recurring action to do maintenance to ensure this list is up-to-date. Let me inquire into this further and if there are any new updates, I'll ensure they get documented and then reply back here.
Hi Brendan,
Did you get hold of the document that you are referring to ?
Thank you.
I've run the latest report for 7.x and the catalog I link to above is up-to-date. There are no critical hot fixes listed after 7.3 for the 7.x release.
Setting : <env name=”lac/traditionalLACRegisterSynch” value=”true” />
When we can get rid of this setting in future? Or the apps in these Pega versions need to live with that forever?
Thank you
Hello Savvy one!
nice question. No, you won't have to keep this forever. When you upgrade to the next forthcoming patch release, you could then get rid of this setting. Changes have already been made in the 8.1.x & 8.2.x patch release streams so that the next patch releases of those that come out later this summer will make the traditional synchronization policy the default
Hi Team,
To avoid the issue, do we need to make both the change as suggested in prconfig & JVM argument, or change in a single place will solve the issue.
Thanks.
Hello Niladri
How are you?
You only need to change one or the other. Both ways control the same setting. You can choose the one that best fits your deployment. If it's easier for you to change the config file, then do that. Or if it's easier to control command line args, then choose that route
Hello Niladari- We were suggested by one of Pega's performance tuning expert, to remove all the settings out of prconfig file and keep them as DSS's, if any JVM args required, add them at the JVM level.
We havebeen following that approach past one year and our applications running stable. I would suggest to go the same way.
Thanks!
Thanks friend, yes I also think the same to update JVM instead config file.
Hi
Is this addressed in pega 8.2.1 version or we have to do this .
is there any specific error related to this setting ?
Hello Ranjithkumar
The problem can occur in 8.2.1. That's why this notice is being communicated.
Please take the appropriate action for your deployment.
There is an optimistic way to detect DEAD locks by using ThreadMXBean, which provides a method called findDeadLockthreads() which returns id of all those threads which are in deadlock and waiting for each other to release monitor or acquire lock.
ThreadMXBean threadMBean = ManagementFactory.getThreadMXBean();
threadMBean.findDeadlockedThreads();
And using this approach we can kill the DEAD locks by doing further optimization capability of System Cleaner agent to do above monitor and kill the dead locks to prevent from system failure.
Could you review this approach with Engineering Team ?
Regards
Bhagath
Certified J2EE / Pega CLSA
Regards
Bhagath
>>> EITHER <<<
prconfig.xml should have to following entry
<env name="lac/traditionalLACRegisterSynch" value="true"/>
>>> OR <<<
JVM argument should be set as
-DNodeSettings=lac/traditionalLACRegisterSynch=true
Has this issue been resolved in 8.2.3 version?
