Flow - Create New Work Object
In the flow rule type, for a default starter flow that gets created once a case gets created, i.e., pyStartCase has a check box - Creates a new work object checked. If i create a new flow, i am finding the checkbox to be disabled. After going through the help file, i removed the pyStartCase flow from the starting flow config in the case type rule and added the new flow rule. yet the check box is disabled. But if i do a save as on the pyStartCase rule i am able to create a new flow with the Create New Work Object check box checked. Can anybody explain me what is the objective behind this?
Thanks in advance.
