Wells Fargo
Last activity: 22 Feb 2018 12:38 EST
Create a new assignment from within a flow
How can create a new assignment from within a flow. I cannot use spin-off, because in that case my current flow would also be submitted when the new assignment is created(parallel process). Also, since I want these two assignments to work independently- I cannot use Split Join.
Let's say the case is currently in WB XYZ. I have a connector flow action directing me to another flow. I want this second sub-process to run on a different assignment. But I don't want the initial case to be submitted past XYZ WB. Spin-off would create a new assignment AND also submit the case from XYZ WB.
How can I achieve this requirement.
Bhagyashree
