Turn on/off notifications per operator
Is there an out-of-the-box solution for turning on/off notifactions for an operator?
Hi Lange,
May we know what kind of notifications you are planning to turn off for the operator, can you elaborate your use case a bit more for our understanding.
Mahesh
Correspondences, i.e. to receive an email or not. Some operators maybe using the system frequently so they would want to turn off the notifications about assignments.
Are you talking about the correspondance notification on/off?
If yes, please check this link a flow named "verifysendcorr" can be used to verify the operator on the basis of
which notifications can be sent to operator.
https://pdn.pega.com/how-enable-verification-correspondence-rules
Thanks NehaMittal,
We're aware of VerifySendCorr, but I can't find what we're looking for. It seems a quite commonly needed feature to me hence I prefered to ask if there's an out-of-the-box solution.
Could you please have a look on the below article :
https://community.pega.com/sites/default/files/help_v721/procomhelpmain.htm
Please let me know if it helps.
Thanks AkshaySinha, but I'm looking for something the other way around. Being able to turn on/off notification for EVERY assignment (where a notificaiton is applicable) to an operator.
Support Doc
