Need to retrieve the archived cases from the DB using Search functionality
I am looking for some guidance regarding search of archived cases from the archive DB . Once the archiving exercise is completed, then the cases will not be no longer available in the Transactional DB. But, if user wants to open the case which is in archive db, then what changes are required in the pega application which can retrieve the case information from archive DB ?
Any thoughts !
-Naren
