Cognizant
Issue with Stage level SLA
I am using stage level SLA to move the stage based on property. I have added the SLA rule in the first stage and in the second stage i have a flow where i have used "split for each" shape to create subcases, after that i have an assignment. Now the issue is, when the SLA rule fires, stage is not getting moved to the second stage but if I bypass the "split for each" step from the flow, then it is working fine.
Can anybody helped me with the resolution. Thanks in advance.
