Tata Consultancy services
Need help in Pega 7.2 personal edition installation error
I'm getting the below data base connection error log while trying to install pega .2 personal edition in windows7 O.S.
Could you please help me out to resolve the issues?
Error log:
[exec] Result: 1
BUILD FAILED
D:\115008_PE72\pegaGuiInstallerTemp\build.xml:156: Unable to connect to database within 15 seconds.
Total time: 42 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
Deekshith.
Error log:
[exec] Result: 1
BUILD FAILED
... 2 more
Deekshith.
***Updated by Maryrita:Moderator, moved from Customer Service to Product Support**
***Moderator Edit: Vidyaranjan| Updated Categories***
