Cognizant
Pega 7.2 Personal Edition: Help not working
I have installed Pega 7.2 Personal Edition,can login successfully but HELP is not working.Could you please help me
Error:
HTTP Status 404 - /prhelp/methods/obj-browse/obj-browse.htm
type Status report
message /prhelp/methods/obj-browse/obj-browse.htm
description The requested resource is not available.
Apache Tomcat/8.5.8
Thanks for the Help
Rajkumar
***Moderator Edit: Vidyaranjan| Updated Categories***
Philips
Could you please check if the Help URL is properly configured?
Cognizant
Hi Shashidhar,
This is my System:Settings.Please let me know,if any changes required.
Cognizant
Can anyone suggest solution for the above problem
Update the Online Help URL to same as what you use to access your PRPC.
Cognizant
Yes it is same.
Online URL is same as PRPC Access URL.
Rajkumar
Philips
I just find out that PE Pega 7.2.2 lacking of SMA and Help war files for deploying on local user PC
Areteans Technology Services
can anyone provide the war for SMA for 7.2.2
Cognizant
Could you please suggest,where i can download SMA and Help war files or have to install manually with already downloaded copy(need exact file names to be installed).
Thanks for the Help
Rajkumar
Can you please try updating the Online Help URL to
Cognizant
Thanks Shashidhar,Help is working now:)
Evoke Technologies
What about SMA Raj?
SopraSteria
I ended up just using the SMA.war from the 7.2.1 PE edition, works fine. No idea why Pega removed SMA from the PE edition other then that they are moving functionality over from the SMA to the regular developer portal. Since not all functionality is available in the regular developer portal SMA is still needed in my view.
Leo
Areteans Technology Solutions
Can you help me on how to use the SMA.war Currently i am using Pega personal edition 7.2. Unable to access SMA. Would be a great help if you could give a walk through on how to install SMA.war.
Ratan Balaji
Techmahindra
Hi Ratan,
Please take the prsysmgmt.war in archives folder where you have both prweb.war and place in the folder of tomcat webapps directory.
Then you can access using http://<hostname>:<portnumber>/prsysmgmt/getnodes.action
Shanthini Charles
Telstra
For help, Go to Designer Studio->System->Settings->URLS
Under resource URLs, for Online Help URL, add https://pdn.pega.com/sites/pdn.pega.com/files/help_v722
This should solve your help issue.
For SMA, If you have Pega 7.2.1 installed on your laptop, you can get prsysmgmt.war file from that installation folder and go to http://localhost:8080 and deploy that via tomcat. It worked for me. PM me if you don't know how to deploy a war file on tomcat.
Capgemini
HI I am using pega 7.2. I am not getting help. please help me. I tried above URL. But its still not working.
Capgemini
Sorry its 7.2.2 version
Updated: 6 Feb 2018 1:19 EST
Capgemini
I pasted 'https://pdn.pega.com/sites/pdn.pega.com/files/help_v722' URL also in app.But still its not working. Some one kindly help me.
<Removed >
Hi Gopi,
Can you go to this link: https://pdn.pega.com/support-downloads/pega-help-systems
You can find online help for 7.2.2 there.
This URL wont work, you should try with https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm to access the designer studio help.
Capgemini
It is also not working. I am getting same error.
Could you share the screenshot of your error in the browser which is launched?
Cognizant Technologies
Download the prhelp.war file and place it tomcat/webapps folder.
Restart the server and then check by relogging.
