Evonsys
Last activity: 7 Sep 2016 5:45 EDT
Candidate case - SAE 1 Course
Can anyone tell me the difference between the SLA that i have highlighted in the below attached images.
Thank You,
Dinesh Ponnusami.
***Updated by Moderator: Vidyaranjan. Removed user added #helpme,FAQ and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
BlueRose Technologies
SE
Hi Dinesh,
That 23 hours is from Goal time column of SLA rule. You can see as one day right.
Prudhvi
PEG
First one is Goal and second one is deadline SLA's.
Please refer https://community.pega.com/sites/default/files/help_v721/procomhelpmain.htm
Evonsys
Hi Gangababu,
I have set the Case level Goal to be 5 days and the Deadline to be 8 days, So the number of days in the image one is 2 which does not match with the number i have set. So its different and I want to know the difference.
Thank You,
Dinesh Ponnusami.
PEG
Can you check the SLA set at assignment level? Incase if set, please remove the SLA and run the use-case then you can find the difference.
Hope this helps!
Evonsys
Hi Gangababu,
The assignment level SLA will be applicable only for the operator of that assignment to perform work within the mentioned time period. But this is common for the entire case level. This is not the Case level SLA either because case level SLA will appear appears the bottom as shown in pega1.jpg image. But i want to know what is the time interval mentioned in pega.jpg.
Thank You,
Dinesh Ponnusami.
Hi Dinesh,
I tried the same at my end too.
My Goal is 5 days and deadline 8 days.
Below is my SLA rule.
When I created a new case, I see it correclty reflected as below.
What you see below the pylabel with a green background is the goal and the one under case contents is the deadline.
I have tried this usecase in Pega 7.1.7. Could you let me know the pega version used at your end?
P.S : I have attached a document with the screenshots of my SLA, Flow and case for your reference.
Gisela
Hi Dinesh,
The time interval mentioned in pega.jpg is the goal time specified in the SLA configured at assignment level.
Please cross verify your goal time specified at your assignment level SLA.
Please find the assignment level SLA configuration in my local environment:
Venkat
Evonsys
Hi Janav,
In the second image you have got 23 hours right, can you show me where you have mentioned it.
Dinesh.
SE
Hi Dinesh,
Prudhvi
Evonsys
Hi Prudhvi,
I got it now. Thank You so much.
Dinesh.
