Last activity: 21 Oct 2016 9:03 EDT
Page refresh having IAC gadget with flow, starts new case
SR-A89817
External website is configured to start a pega flow using IAC. Flow as screen flow. User completes few screens and clicks on F5/refresh button. Whole data is lost and new case is created, which is not expected. User need to go to same state before refresh. Simillar to how PEGA 7 maintain the desktop state.
Is there any way we can achive this fuctionality.
Krishna
***Updated by Moderator: Lochan. Removed user added Ask the Expert. Apologies for confusion, shouldn't have been an end-user option***
***Updated by Moderator: Vidyaranjan| Tagged SRCreated- Included SR details ***
Hello Krishna,
The corresponding SR has been closed because there was no response. Please feel free to continue this discussion if you are still seeking assistance.
Hope to see you around the Community!
Lochan | Community Moderator | Pegasystems Inc.
Hello Krishna,
Thanks for raising your query.
From your post, I understand that the case is created when you refresh the page from browser refresh and while it is accessed from Pega application using IAC. Do you see the behavior when the flow is executed without using IAC configured? Also, what is the product version used at your end?
Rincy
Hi Rincy,
Thanks for the quick reply.
We use below code to display pega gadget in external web site.
<div id="DigitalMashup" style="overflow:auto;"
PegaGadget="DigitalMashup"
PegaResize="stretch"
PegaA="createNewWork"
PegaA_className="GKC-CSS-Work-Sales-Home"
PegaA_flowName="CollectCustomerData"
PegaA_model="pyDefault"
PegaDefer="false"
PegaA_params="{UserIdentifier:'[page/id/OperatorID]',Password:'RDFnMXQ0TA%3D%3D'}"
PegaE_OnLoad = "window.scrollTo(0,0)">
</div>
I tested the same in CPM Interaction portal, case state is as is even after the browser refresh.
Product version used is CS 7.1.4 on Pega 7.1.9.
Hope we have a solution for this issue.
Krishna
Hello Krishna,
Thanks for the response and confirming the product version used at your end.
From your latest response, I understand that when you try to execute the same flow(as screenflow) from CS 7.1.4 on Pega 7.1.9, new case is not created even if user refreshes the browser(using F5 or right click). Is my understanding correct?
Rincy
Yes Rincy, new case is not created after browser refresh in non-IAC application.
Note: there is a little difference how we Launch the case in IAC and non-IAC portals.
In IAC portal service cases are created directly, but in non-IAC portal service cases are created from interaction cases. Not sure whether this make any difference.
Krishna
Hello Krishna,
Thanks for the response.
As this would need investigation, I would suggest you to raise a Support request. This is to identify if there are any configuration/environmental issues at your end related to IAC gadget.
Rincy
Hi Rincy,
As suggeted raised SR-A89817.
Krishna
Hello Krishna,
