Capgemini
Last activity: 9 Oct 2015 8:06 EDT
Unable to login pega with any of the accounts
We are unable to login pega with any of the user accounts. Always it's just displaying Error "The information you entered was not recognized."
Is there any way to reset the passwords or can get the back-end tables updated with the correct information (or) Please help us with the resolution.
Environment:
Tomcat 7
Pega v.7.1.5
Oracle 11g
Windows Server 2008 R2
Thank you very much for your help,
Rohith Reddy J
Is it all user accounts or can you login as [email protected] (default password "install")?
Capgemini
it's for all accounts including [email protected]
JP
Did it happen all of sudden or were you configuring some authentication related settings before the system locks out all user?
Capgemini
it happened suddenly. Not sure whether any of the developer changed any setting in requestor type
Capgemini
we don't have any LDAP system here. authentication is happening within pega.
Below is the log for the issuue
2015-09-18 16:54:26,766 [ IN-HYD-BPM] [ STANDARD] [ ] [ ] (tener.ListenerStateManagerImpl) ERROR - Unexpected exception.
com.pega.pegarules.pub.PRException: Failed to start listener: File.Services
From: (AC60EA76921EED40B31EFAA47D0AA652B:(Engine Startup Init Services))
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerWrapper.launchListener(ListenerWrapper.java:190)
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerStateManagerImpl.startOneListener(ListenerStateManagerImpl.java:733)
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerStateManagerImpl.startServiceTypeListeners(ListenerStateManagerImpl.java:483)
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerStateManagerImpl.startListenerType(ListenerStateManagerImpl.java:435)
at com.pega.pegarules.integration.engine.internal.PRIntegrationEngineProviderImpl.initServices(PRIntegrationEngineProviderImpl.java:172)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.initServices(PREnvironment.java:620)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1203)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:930)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:815)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.finishInit(PREnvironment.java:522)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:376)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1913)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:640)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:266)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:174)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:419)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:460)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:509)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4994)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5492)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1081)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1877)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.pega.pegarules.pub.PRException: Authentication failed for listener: File.Services
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl$1.run(ServiceListenerBaseImpl.java:395)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1192)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:781)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.init(ServiceListenerBaseImpl.java:358)
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerWrapper.launchListener(ListenerWrapper.java:183)
... 48 more
Caused by: com.pega.pegarules.pub.PRException: PRException
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.setRequestorPrivileges(ServiceAPI.java:3107)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl$1.run(ServiceListenerBaseImpl.java:391)
... 53 more
Caused by: com.pega.pegarules.pub.services.ServiceException: Authentication failed
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.handleAuthentication(ServiceAPI.java:1584)
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.setRequestorPrivileges(ServiceAPI.java:3098)
... 54 more
2015-09-18 16:54:27,074 [ FILE-Thread-7] [ STANDARD] [ ] [ ] ( fs.resadaptor.RAFile) INFO File.TestFileLIS|initialize - RAFile will use File System
2015-09-18 16:54:27,078 [ FILE-Thread-7] [ STANDARD] [ ] [ ] ( services.file.FileListener) ERROR File.TestFileLIS - Unexpected exception caught during processing.
java.lang.Exception: [D:\HSBC Work\Test] does not exist.
at com.pega.pegarules.integration.engine.internal.services.file.FileListener.initialize(FileListener.java:1803)
at com.pega.pegarules.integration.engine.internal.services.file.FileListener.run_(FileListener.java:1878)
at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:448)
Hi Jetti - the log snippet appear to show an issue with an 'A*' requestor (a 'Service' Requestor : in this case relating to a File Listener) rather than a 'H*' requestor (a 'HTTP (browser)' Requestor).
But may the two are inter-related.
You mentioned this :
Is something that could have happened you think ?
You might want to consider logging an SR for this....
John
Updated: 18 Sep 2015 8:55 EDT
JP
Marty Solomon reported Bug-208976 before, which caused him could not login the PRPC at all, but in that case he was trying to configure the system so the number of login sessions per operator can be limited.
If you do end up raising an SR, please let us know and tell us what the SR number is. When SRs are raised from discussions, we want to associate the two as additional reference for clarification.
There's no need to rehash questions if they've already been discussed here right?
Oh, and thanks for giving me a topic to write about in this week's update
Thanks.
B.
Are you using any custom authentication methods here ? (LDAP server or something?)
Do you get anything in the logs ?
It seems odd that all users should suddenly blocked: unless the authentication process is 'outsourced' to another system (usually LDAP) - which perhaps is not running or unreachable ?
From Rohith:
We have upgraded that same environment to the higher version & we didn't see this type of issue, in the latest version pega 716.
