Carelon Global Solutions
Last activity: 27 Nov 2016 3:24 EST
unable to login to PEGA designer studio with default credentials
I have installed Pega 7.1.7 on Oracle 12c db and weblogic 12c application server.
Java-jdk1.7.0_45.
When I try to login to PEGA designer studio with default id/pwd i.e [email protected] I am getting below error.
Please help me out.
Could you please attach the complete logs when tried to log-in ?
Can you verify if any modifications have been done on pr_operators table in DB ?
Hi Shashidhar,
Please find the log below.
Looks like PR_OPERATORs table was updated. Actually alredy sepup was there earlier and later DB server decommissioned. so new db server created and installed PEGA.
I can see few users created in PR_OPERATORS table same as Dev DB users.
How to resolve this issue.
v 23 10:14:15 AST 2016 Total memory: 2,595,749,888 Free memory: 2,010,058,472 Requestor Count: 10 Shared Pages memory usage: 0%
2016-11-23 10:22:57,343 [fault (self-tuning)'] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR xxxxx.xx.xx.co
m|10.xx.xx.xx - Encountered problem when performing a Commit
Hi Shashidhar,
com.pega.pegarules.pub.PRRuntimeException: Encountered database exception when preprocessing deferred operations <update instance DATA-ADMIN-OPERATOR-ID Proprietary information hidden not only if new>. Error occurred while executing forward chaining on page '', using rule: {pyClassName=@baseclass, pxObjClass=Rule-Declare-Expressions, pyTargetProperty=.pxRuleOpenedInPopUp, pyPageContext=}
at com.pega.pegarules.data.internal.access.DatabaseImpl.preprocessInstancesBeforeCriticalCommitSection(DatabaseImpl.java:3135)
at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2608)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2288)
at com.pega.pegarules.data.internal.access.Saver.save(Saver.java:663)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4930)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4916)
at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:4908)
at com.pega.pegarules.session.internal.mgmt.authentication.Authentication.initializeUser(Authentication.java:1850)
at com.pega.pegarules.session.internal.mgmt.authentication.Authentication.initializeUser(Authentication.java:1772)
at com.pega.pegarules.session.internal.mgmt.authentication.Authentication.doAuthentication(Authentication.java:520)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.handleAuthentication(HttpAPI.java:2168)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.activityExecutionProlog(EngineAPI.java:547)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:382)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1188)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:926)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:811)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:330)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:839)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:240)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:485)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:290)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:118)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:341)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:238)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3363)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3333)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2220)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2146)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2124)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1564)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:295)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:254)
Caused by: com.pega.pegarules.pub.PRRuntimeException: Error occurred while executing forward chaining on page '', using rule: {pyClassName=@baseclass, pxObjClass=Rule-Declare-Expressions, pyTargetProperty=.pxRuleOpenedInPopUp, pyPageContext=}
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngineUtilImpl.runActivity(ChainingEngineUtilImpl.java:260)
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngineUtilImpl.executeBackwardChainingRule(ChainingEngineUtilImpl.java:393)
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngine.deriveGoalValue(ChainingEngine.java:491)
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngine.forceFeedDeriveGoalValue(ChainingEngine.java:401)
at com.pega.pegarules.exec.internal.declare.infengine.InferenceEngineImpl.seekGoalValue(InferenceEngineImpl.java:524)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.seekValue(ClipboardPropertyBase.java:1229)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.autoChain(ClipboardPropertyImpl.java:1187)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.autoChain(ClipboardPropertyImpl.java:922)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.autoChain(ClipboardPropertyBase.java:3235)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getValue(ClipboardPropertyImpl.java:4291)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getValue(ClipboardPropertyImpl.java:4282)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getStringValue(ClipboardPropertyImpl.java:3530)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getStringValue(ClipboardPropertyImpl.java:3534)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoder$PageSection.addProperty(DirectStreamEncoder.java:916)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoder$PageSection.addPage(DirectStreamEncoder.java:743)
at com.pega.pegarules.data.internal.clipboard.DirectStreamEncoder.encode(DirectStreamEncoder.java:317)
at com.pega.pegarules.data.internal.clipboard.StorageStreamCommonImpl.encode(StorageStreamCommonImpl.java:825)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getStreamForm(ClipboardPageImpl.java:3619)
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.getStreamFormOfPage(PageDatabaseMapperImpl.java:1448)
at com.pega.pegarules.data.internal.access.DatabaseImpl.preprocessInstancesBeforeCriticalCommitSection(DatabaseImpl.java:3070)
... 56 more
Caused by: java.lang.NoClassDefFoundError: com/pega/push/notification/unifiedpush/message/UnifiedMessage
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2531)
at java.lang.Class.getMethod0(Class.java:2774)
at java.lang.Class.getMethod(Class.java:1663)
at com.pega.pegarules.generation.internal.library.LibraryMetadataCache.getLibraryCache(LibraryMetadataCache.java:167)
at com.pega.pegarules.generation.internal.library.LibraryMetadataCache.libraryContainsSignature(LibraryMetadataCache.java:379)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.resolveMethodCall(LibraryFunctionUtilityImpl.java:2921)
at com.pega.pegarules.session.internal.mgmt.Executable.resolveMethodCall(Executable.java:10960)
at com.pegarules.generated.expressions.ra_action__pxruleopenedinpopup__e115ffea35b71731e01ca60c2fef6d21.perform(ra_action__pxruleopenedinpopup__e115ffea35b71731e01ca60c2fef6d21.java:122)
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3180)
at com.pega.pegarules.exec.internal.declare.infengine.ChainingEngineUtilImpl.runActivity(ChainingEngineUtilImpl.java:227)
... 75 more
Caused by: java.lang.ClassNotFoundException: com.pega.push.notification.unifiedpush.message.UnifiedMessage
at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.findClass(PRBaseLoader.java:312)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at com.pega.pegarules.internal.bootstrap.phase2.PRBaseLoader.loadClass(PRBaseLoader.java:237)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at com.pega.pegarules.bootstrap.loader.PRAppLoader.loadClass(PRAppLoader.java:796)
at com.pega.pegarules.bootstrap.loader.PRAppLoader.loadClass(PRAppLoader.java:659)
at com.pega.pegarules.exec.internal.util.classloader.PRClassLoaderDB.loadClass(PRClassLoaderDB.java:1034)
at com.pega.pegarules.exec.internal.util.classloader.PRClassLoaderDB$Loader.loadClass(PRClassLoaderDB.java:2038)
... 86 more
2016-11-23 10:22:57,346 [fault (self-tuning)'] [ STANDARD] [ ] [ PegaRULES:07.10] (.authentication.Authentication) ERROR xxxxxxxxxxx|10.xx.xx.xx - Cannot save Data-Admin-Operator-ID instance to database.com.pega.pegarules.pub.PRRuntimeException: Encountered database exception when preprocessing deferred operations <update instance DATA-ADMIN-OPERATOR-ID Proprietary information hidden not only if new>. Error occurred while executing forward chaining on page '', using rule: {pyClassName=@baseclass, pxObjClass=Rule-Declare-Expressions, pyTargetProperty=.pxRuleOpenedInPopUp, pyPageContext=}
Can some one please help me out.
Gurudatt
Please see the error logs while installing the PEGA.
[java] 2016-11-24 20:05:14,570 [ xxxxxx] [ STANDARD] [ ] (l.access.ConnectionManagerImpl) ERROR - Not returning connection 7 for database "pegarules" to the pool as it previously encountered the following error
20605 [java] User ID: (unknown)
20606 [java] Last SQL: {call PRPC_DATA_USR.sppr_sys_updatescache_gettime (?,?,?)}
20607 [java] java.sql.SQLException: ORA-06598: insufficient INHERIT PRIVILEGES privilege
20608 [java] ORA-06512: at "PRPC_DATA_USR.SPPR_SYS_UPDATESCACHE_GETTIME", line 1
20609 [java] ORA-06512: at line 1
20588,6 90%
20657 [java] 2016-11-24 20:05:14,573 [ xxxxx] [ STANDARD] [ ] ( internal.access.DatabaseImpl) ERROR - [setDataNodeState] Excep tion while updating system state. Message: Database-General Problem encountered executing a stored procedure 6598 65000 ORA-06598: insufficient INHE RIT PRIVILEGES privilege
20658 [java] ORA-06512: at "PRPC_DATA_USR.SPPR_SYS_UPDATESCACHE_GETTIME", line 1
20659 [java] ORA-06512: at line 1
20660 [java]
20661 [java] com.pega.pegarules.pub.database.DatabaseException: Database-General Problem encountered executing a stored procedure 6598 65000 ORA-06598: insufficient INHERIT PRIVILEGES privilege
20662 [java] ORA-06512: at "PRPC_DATA_USR.SPPR_SYS_UPDATESCACHE_GETTIME", line 1
20663 [java] ORA-06512: at line 1
20664 [java]
20665 [java] From: (BCFB9A46EC04785FAA7376E0AEEFC65F0:(PREnvironment))
20666 [java] SQL: {call PRPC_DATA_USR.sppr_sys_updatescache_gettime (?,?,?)}
20667 [java] SQL Inserts: <SYSTEM-STATUS-NODES PRPC!SARYPTINTAPP!777F12059A712282D20E0700AD4C85A6> <1970-01-01 03:00:00.0> <1970-01-01 03:00:00.0>
20668 [java]
20669 [java] Caused by SQL Problems.
20670 [java] Problem #1, SQLState 65000, Error code 6598: java.sql.SQLException: ORA-06598: insufficient INHERIT PRIVILEGES privilege
20671 [java] ORA-06512: at "PRPC_DATA_USR.SPPR_SYS_UPDATESCACHE_GETTIME", line 1
20672 [java] ORA-06512: at line 1
