ACC3 International
Last activity: 2 Nov 2015 10:28 EST
Not able to fully configure TMF 7.1.2 on 7.1.9
After installing TMF 7.1.2, we are unable to add an application to our environment per below instruction guide. We do not know of any more recent config guides
https://pdn.pega.com/test-management-framework-tmf/configuring-the-framework
Pegasystems
You are correct. There is no linkage between DCO specifications and requirements and test cases in TMF 7.1.2. So you would either have to create user stories to link the tests to, or features, or ad hoc coverages.
have you checked the documentation here: https://collaborate.pega.com/question/agile-studio-73-integration-tmf-test-management-framework
Jessica Haider can you help with TMF
ACC3 International
We checked into that documentation, but it did not help with configuration. The only configuration document we found was for 6.1
Pegasystems
TMF 7.1.2 doesn't include integration with development environments. It has transitioned to using Products (which can be defined in PMF/TMF) instead of Applications.
The PDN article linked to above (https://pdn.pega.com/test-management-framework-tmf/configuring-the-framework) is old and not valid for TMF 7.1.2.
The set of documentation for TMF 7.1.2 is at the link that Kevin provided: https://collaborate.pega.com/question/agile-studio-73-integration-tmf-test-management-framework
ACC3 International
Thanks for the response Jessica. I went through the documentation but there doesn't seem to be anything about setup outside of configuring the email address and test case related items. Is the below correct:
Since there is no integration with dev, we cannot access the specs and recs created in DCO? If this is the case, does that mean after we create a product in TMF, we then have to create the user stories in TMF?
Zach
Pegasystems
ACC3 International
Ok, thank you very much for the help!
