Capgemini
org.postgresql.util.PSQLException: This connection has been closed when installing pega719
Hello Team,
We are trying to install Pega719 in Linux with postgreSQL db. we have correctly installed postgreSQL DB & created rules and data schema.
PLJava
Contains a sql script, java archive and related shared library to enable Postgres 9.3 to be con
figured to support Java User Defined Functions (UDF).
This is a pre-installation step that needs to be performed before Pega 7 installation is attemp
ted. These steps assume a supported version of Java is
already installed and accessible (java -version).
For Linux:
1)created a symbolic link for libjvm.so in /lib64
ln -s /usr/java/jdk1.6.0_45/jre/lib/amd64/server/libjvm.so /lib64/libjvm.so
2) Copied pljava.so and pljava.jar, deploy.jar files from the ResourceKit folder to the <Postgres Home>/lib directory (typically /usr/pgsql-9.3/lib)
3) Updated the postgres.conf file located in data directory (typically /var/lib/pgsql/9.3/data) with the settings below where
<Postgres Home> is the path to the Postgres lib directory using normal Linux single slashes as path
seperators
work_mem = 5MB
pljava.classpath='<Postgres Home>/lib/pljava.jar'
But, while performing installation, installation is getting struck at the below specified point. Can somebody please help me on this.
Hello Team,
PLJava
For Linux:
seperators
work_mem = 5MB
Thanks you very much in advance.
_________________________________________________________________________________________________________________
Install UDF Jar:
[java] 2015-12-26 21:23:24,690 ( DatabaseLibraryLoader) INFO - Loading user-defined functions into the database.
[java] 2015-12-26 21:23:24,725 ( DatabaseLibraryLoader) INFO - Using a Postgres database.
[java] 2015-12-26 21:23:26,269 ( DatabaseLibraryLoader) INFO - Jar is not already loaded.
[java] 2015-12-26 21:23:26,552 ( DatabaseLibraryLoader) WARNING - Encountered a database problem when attempting to load jar onto PostgreSQL: This connection has been closed.
[java]
[java] org.postgresql.util.PSQLException: This connection has been closed.
[java] at org.postgresql.jdbc.PgConnection.checkClosed(PgConnection.java:750)
[java] at org.postgresql.jdbc.PgConnection.setAutoCommit(PgConnection.java:709)
[java] at com.pega.pegarules.install.DatabaseLibraryLoader.installJarOnPostgres(DatabaseLibraryLoader.java:279)
[java] at com.pega.pegarules.install.DatabaseLibraryLoader.runMainProgramWithoutExiting(DatabaseLibraryLoader.java:226)
[java] at com.pega.pegarules.install.DatabaseLibraryLoader.main(DatabaseLibraryLoader.java:144)
[java] 2015-12-26 21:23:26,552 ( DatabaseLibraryLoader) INFO -
[java] *****************************************************************************************************
[java]
[java] Encountered database error attempting to load UDF library onto PostgreSQL, clean schema before running again.
[java]
