get error Unable to load class: org.postgresql.Driver when installing Pega 8.64
Dear Pega Support,
I'm encounter error "Unable to load class: org.postgresql.Driver" when installing Pega 8.64. following is the script I used to install. please advice, thanks.
Show More
Dear Pega Support,
[root@devpega /]# export JAVA_HOME=/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b06-11.el8.x86_64/jre
[root@devpega /]# java -jar "usr/share/java/postgresql-jdbc.jar"
PostgreSQL JDBC Driver 42.3.6
Found in: jar:file:/usr/share/java/postgresql-jdbc.jar!/org/postgresql/Driver.class
The PgJDBC driver is not an executable Java program.
You must install it according to the JDBC driver installation instructions for your application / container / appserver, then use it by specifying a JDBC URL of the form
jdbc:postgresql://
or using an application specific method.
See the PgJDBC documentation: http://jdbc.postgresql.org/documentation/head/index.html
This command has had no effect.
[root@devpega /]# java -version
openjdk version "1.8.0_322"
OpenJDK Runtime Environment (build 1.8.0_322-b06)
OpenJDK 64-Bit Server VM (build 25.322-b06, mixed mode)
[root@devpega /]# su postgres
bash-4.4$ psql
psql (11.16)
Type "help" for help.
postgres=# exit
bash-4.4$ exit
exit
[root@devpega /]# cd usr
[root@devpega usr]# cd 117230_Pega8.64
[root@devpega 117230_Pega8.64]# cd scripts
[root@devpega scripts]# ./install.sh
Buildfile: /usr/117230_Pega8.64/scripts/setupDatabase.xml
install:
Initialization:
[echo] Performing Install Finalization
[delete] Deleting directory /usr/117230_Pega8.64/scripts/taskRuntimes
[mkdir] Created dir: /usr/117230_Pega8.64/scripts/taskRuntimes
[delete] Deleting: /usr/117230_Pega8.64/scripts/logs/Warnings.log
[pega:propertyparser] Reading Properties from: /usr/117230_Pega8.64/scripts/setupDatabase.properties
[pega:propertyparser] pega.jdbc.driver.class=org.postgresql.Driver
[pega:propertyparser] update.existing.applications=false
[pega:propertyparser] bypass.udf.generation=
[pega:propertyparser] pega.jdbc.password=*****
[pega:propertyparser] update.applications.schema=false
[pega:propertyparser] automatic.resume=true
[pega:propertyparser] pega.jdbc.driver.jar=usr/share/java/postgresql-jdbc.jar
[pega:propertyparser] rules.schema.name=pegarules
[pega:propertyparser] run.ruleset.cleanup=true
[pega:propertyparser] pega.jdbc.url=jdbc:postgresql://localhost:5432/pega
[pega:propertyparser] pega.database.type=postgres
[pega:propertyparser] user.temp.dir=
[pega:propertyparser] db2zos.udf.wlm=
[pega:propertyparser] production.level=2
[pega:propertyparser] pega.zos.properties=
[pega:propertyparser] customerdata.schema.name=
[pega:propertyparser] pega.jdbc.username=pegadev
[pega:propertyparser] bypass.pega.schema=
[pega:propertyparser] pega.admin.password=*****
[pega:propertyparser] data.schema.name=pegadata
[pega:propertyparser] system.name=pega
[echo] Using logging configuration from: /usr/117230_Pega8.64/scripts/config/deploylogging.properties
[echo] *** JVM Arguments -Xmx4g -XX:+HeapDumpOnOutOfMemoryError -Djava.util.logging.config.file='/usr/117230_Pega8.64/scripts/config/deploylogging.properties' ***
[pega:hasenoughspace] Found 45461180KB of free space on '/tmp'
[echo] Driver Path: usr/share/java/postgresql-jdbc.jar
[pega:getbuildcodesetversion] Found runtime codeset version FS_ONLY
[pega:getbuildcodesetversion] Found manifest codeset version 08-06-05
[mkdir] Created dir: /tmp/PegaInstallTemp-07-July-2022-11.34.18/load
[mkdir] Created dir: /tmp/PegaInstallTemp-07-July-2022-11.34.18/pr_temp
[touch] Creating /usr/117230_Pega8.64/scripts/logs/Warnings.log
[echo] Using /tmp/PegaInstallTemp-07-July-2022-11.34.18 for install scratch space...
[copy] Copying 1 file to /tmp/PegaInstallTemp-07-July-2022-11.34.18/load
[pega:generateengineclasspath] Unzipping jars from /usr/117230_Pega8.64/archives/pegadbinstall-classes.zip to /tmp/PegaInstallTemp-07-July-2022-11.34.18/load
Checking Configuration Files:
[echo] Rules schema has been set to 'pegarules'
Processing Configuration Files:
[propertyfile] Creating new property file: /tmp/PegaInstallTemp-07-July-2022-11.34.18/prbootstrap.properties
Configuration:
[echo] Database Type: postgres
[echo] JDBC Driver JAR: usr/share/java/postgresql-jdbc.jar
[echo] Bootstrap Config: /tmp/PegaInstallTemp-07-July-2022-11.34.18/prbootstrap.properties
[echo] PegaRULES Config: /tmp/PegaInstallTemp-07-July-2022-11.34.18/prconfig.xml
[echo] PegaRULES Logging Config: /tmp/PegaInstallTemp-07-July-2022-11.34.18/prlog4j2.xml
Generate DDL:
[echo] rules.schema=pegarules
[echo] data.schema=pegadata
[echo] customerdata.schema=pegadata
[delete] Deleting directory /usr/117230_Pega8.64/schema/generated/postgres/install
[mkdir] Created dir: /usr/117230_Pega8.64/schema/generated/postgres/install
[mkdir] Created dir: /usr/117230_Pega8.64/schema/generated/postgres/util
_init:
_callDDLUtility:
[echo] Call DDL Generation Utility...
[echo] /usr/117230_Pega8.64/scripts/lib/xercesImpl.jar;/usr/117230_Pega8.64/scripts/lib/xml-apis.jar;/usr/117230_Pega8.64/scripts/lib/resolver.jar;
[echo] archive_dir: /usr/117230_Pega8.64/scripts/lib
[java] 2022-07-07 11:34:50,107 ( SchemaGenerator) INFO - Cleaning up previous invocation...
[java] 2022-07-07 11:34:50,282 ( SchemaGenerator) INFO - Cleaning up previous invocation...(Complete)
[java] 2022-07-07 11:34:50,284 ( SchemaGenerator) INFO - Creating output directory at /usr/117230_Pega8.64/scripts/../schema/generated/postgres
[java] 2022-07-07 11:34:50,303 ( SchemaGenerator) INFO - URL: jar:file:/usr/117230_Pega8.64/scripts/lib/prmaster-schema.jar!/schema/pegarules-master.xml
[java] 2022-07-07 11:34:51,867 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:34:51,871 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:34:51,875 ( install) INFO - Getting document builder
[java] 2022-07-07 11:34:55,201 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:34:55,213 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/pega_schema.xsd
[java] 2022-07-07 11:34:56,002 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_assignment_summary.sql
[java] 2022-07-07 11:34:56,010 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_assignment_summary.sql
[java] 2022-07-07 11:34:56,014 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_assignment_summary.sql
[java] 2022-07-07 11:34:56,019 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_assignment_summary.sql
[java] 2022-07-07 11:34:56,051 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_assignment_summary.sql
[java] 2022-07-07 11:34:56,053 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_assignment_summary_mt.sql
[java] 2022-07-07 11:34:56,054 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_assignment_summary_mt.sql
[java] 2022-07-07 11:34:56,057 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_assignment_summary_mt.sql
[java] 2022-07-07 11:34:56,063 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_assignment_summary_mt.sql
[java] 2022-07-07 11:34:56,065 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_assignment_summary_mt.sql
[java] 2022-07-07 11:34:56,067 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_assignmentwb_summary.sql
[java] 2022-07-07 11:34:56,068 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_assignmentwb_summary.sql
[java] 2022-07-07 11:34:56,073 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_assignmentwb_summary.sql
[java] 2022-07-07 11:34:56,075 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_assignmentwb_summary.sql
[java] 2022-07-07 11:34:56,076 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_assignmentwb_summary.sql
[java] 2022-07-07 11:34:56,078 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_assignmentwb_summary_mt.sql
[java] 2022-07-07 11:34:56,079 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_assignmentwb_summary_mt.sql
[java] 2022-07-07 11:34:56,080 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_assignmentwb_summary_mt.sql
[java] 2022-07-07 11:34:56,082 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_assignmentwb_summary_mt.sql
[java] 2022-07-07 11:34:56,093 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_assignmentwb_summary_mt.sql
[java] 2022-07-07 11:34:56,094 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_work_history.sql
[java] 2022-07-07 11:34:56,095 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_work_history.sql
[java] 2022-07-07 11:34:56,097 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_work_history.sql
[java] 2022-07-07 11:34:56,098 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_work_history.sql
[java] 2022-07-07 11:34:56,102 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_work_history.sql
[java] 2022-07-07 11:34:56,104 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pcv4_work_history_mt.sql
[java] 2022-07-07 11:34:56,105 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pcv4_work_history_mt.sql
[java] 2022-07-07 11:34:56,106 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pcv4_work_history_mt.sql
[java] 2022-07-07 11:34:56,108 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pcv4_work_history_mt.sql
[java] 2022-07-07 11:34:56,109 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pcv4_work_history_mt.sql
[java] 2022-07-07 11:34:56,110 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_circumstance_duplicates.sql
[java] 2022-07-07 11:34:56,112 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_circumstance_duplicates.sql
[java] 2022-07-07 11:34:56,113 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_circumstance_duplicates.sql
[java] 2022-07-07 11:34:56,120 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_circumstance_duplicates.sql
[java] 2022-07-07 11:34:56,126 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_circumstance_duplicates.sql
[java] 2022-07-07 11:34:56,127 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_circumstance_duplicates_mt.sql
[java] 2022-07-07 11:34:56,128 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_circumstance_duplicates_mt.sql
[java] 2022-07-07 11:34:56,129 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_circumstance_duplicates_mt.sql
[java] 2022-07-07 11:34:56,130 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_circumstance_duplicates_mt.sql
[java] 2022-07-07 11:34:56,151 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_circumstance_duplicates_mt.sql
[java] 2022-07-07 11:34:56,152 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_locking.sql
[java] 2022-07-07 11:34:56,153 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_locking.sql
[java] 2022-07-07 11:34:56,155 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_locking.sql
[java] 2022-07-07 11:34:56,156 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_rule_locking.sql
[java] 2022-07-07 11:34:56,157 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_locking.sql
[java] 2022-07-07 11:34:56,158 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_locking_mt.sql
[java] 2022-07-07 11:34:56,159 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_locking_mt.sql
[java] 2022-07-07 11:34:56,160 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_locking_mt.sql
[java] 2022-07-07 11:34:56,161 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_rule_locking_mt.sql
[java] 2022-07-07 11:34:56,168 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_locking_mt.sql
[java] 2022-07-07 11:34:56,169 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_overrides.sql
[java] 2022-07-07 11:34:56,170 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_overrides.sql
[java] 2022-07-07 11:34:56,171 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_overrides.sql
[java] 2022-07-07 11:34:56,172 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_rule_overrides.sql
[java] 2022-07-07 11:34:56,199 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_overrides.sql
[java] 2022-07-07 11:34:56,200 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_overrides_mt.sql
[java] 2022-07-07 11:34:56,201 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_overrides_mt.sql
[java] 2022-07-07 11:34:56,202 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_overrides_mt.sql
[java] 2022-07-07 11:34:56,204 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/view/pwbv4_rule_overrides_mt.sql
[java] 2022-07-07 11:34:56,205 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_overrides_mt.sql
[java] 2022-07-07 11:34:56,206 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_overrides_all.sql
[java] 2022-07-07 11:34:56,207 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_overrides_all.sql
[java] 2022-07-07 11:34:56,209 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_overrides_all.sql
[java] 2022-07-07 11:34:56,210 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_overrides_all.sql
[java] 2022-07-07 11:34:56,211 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/pwbv4_rule_overrides_all_mt.sql
[java] 2022-07-07 11:34:56,212 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/view/pwbv4_rule_overrides_all_mt.sql
[java] 2022-07-07 11:34:56,213 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/view/pwbv4_rule_overrides_all_mt.sql
[java] 2022-07-07 11:34:56,214 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/view/pwbv4_rule_overrides_all_mt.sql
[java] 2022-07-07 11:34:56,215 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/prv4_system_queues.sql
[java] 2022-07-07 11:34:56,216 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/view/prv4_system_queues_mt.sql
[java] 2022-07-07 11:34:56,218 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_compare_value_lists.sql
[java] 2022-07-07 11:34:56,230 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_compare_value_lists.sql
[java] 2022-07-07 11:34:56,234 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_compare_value_lists.sql
[java] 2022-07-07 11:34:56,236 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_compare_value_lists.sql
[java] 2022-07-07 11:34:56,237 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_compare_value_lists.sql
[java] 2022-07-07 11:34:56,238 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_compare_value_lists_allof.sql
[java] 2022-07-07 11:34:56,240 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_compare_value_lists_allof.sql
[java] 2022-07-07 11:34:56,241 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_compare_value_lists_allof.sql
[java] 2022-07-07 11:34:56,242 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_compare_value_lists_allof.sql
[java] 2022-07-07 11:34:56,243 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_compare_value_lists_allof.sql
[java] 2022-07-07 11:34:56,244 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_compare_value_lists_anyof.sql
[java] 2022-07-07 11:34:56,260 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_compare_value_lists_anyof.sql
[java] 2022-07-07 11:34:56,261 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_compare_value_lists_anyof.sql
[java] 2022-07-07 11:34:56,262 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_compare_value_lists_anyof.sql
[java] 2022-07-07 11:34:56,263 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_compare_value_lists_anyof.sql
[java] 2022-07-07 11:34:56,264 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_read_from_stream.sql
[java] 2022-07-07 11:34:56,265 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_read_from_stream.sql
[java] 2022-07-07 11:34:56,277 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_from_stream.sql
[java] 2022-07-07 11:34:56,278 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_from_stream_mt.sql
[java] 2022-07-07 11:34:56,279 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_from_stream.sql
[java] 2022-07-07 11:34:56,280 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_from_stream_mt.sql
[java] 2022-07-07 11:34:56,281 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_read_from_stream.sql
[java] 2022-07-07 11:34:56,282 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_read_decimal_from_stream.sql
[java] 2022-07-07 11:34:56,283 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_read_decimal_from_stream.sql
[java] 2022-07-07 11:34:56,284 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_decimal_from_stream.sql
[java] 2022-07-07 11:34:56,284 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_decimal_from_stream_mt.sql
[java] 2022-07-07 11:34:56,286 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_decimal_from_stream.sql
[java] 2022-07-07 11:34:56,287 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_decimal_from_stream_mt.sql
[java] 2022-07-07 11:34:56,287 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_read_decimal_from_stream.sql
[java] 2022-07-07 11:34:56,291 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/function/pr_read_int_from_stream.sql
[java] 2022-07-07 11:34:56,291 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/function/pr_read_int_from_stream.sql
[java] 2022-07-07 11:34:56,292 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_int_from_stream.sql
[java] 2022-07-07 11:34:56,293 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/function/pr_read_int_from_stream_mt.sql
[java] 2022-07-07 11:34:56,294 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_int_from_stream.sql
[java] 2022-07-07 11:34:56,295 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/function/pr_read_int_from_stream_mt.sql
[java] 2022-07-07 11:34:56,296 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/function/pr_read_int_from_stream.sql
[java] 2022-07-07 11:34:56,297 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_purge_table_no_logging.sql
[java] 2022-07-07 11:34:56,430 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_purge_table_no_logging.sql
[java] 2022-07-07 11:34:56,432 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/SPPR_PURGE_TABLE.sql
[java] 2022-07-07 11:34:56,434 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_purge_table.sql
[java] 2022-07-07 11:34:56,505 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_purge_table.sql
[java] 2022-07-07 11:34:56,507 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_purge_table.sql
[java] 2022-07-07 11:34:56,508 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_purge_table.sql
[java] 2022-07-07 11:34:56,512 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppc_data_uniqueid_withouttran.sql
[java] 2022-07-07 11:34:56,517 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppc_data_uniqueid_withouttran_mt.sql
[java] 2022-07-07 11:34:56,519 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppc_data_uniqueid_withouttran.sql
[java] 2022-07-07 11:34:56,520 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppc_data_uniqueid_withouttran_mt.sql
[java] 2022-07-07 11:34:56,521 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppc_data_uniqueid.sql
[java] 2022-07-07 11:34:56,523 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppc_data_uniqueid_mt.sql
[java] 2022-07-07 11:34:56,524 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppc_data_uniqueid.sql
[java] 2022-07-07 11:34:56,526 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppc_data_uniqueid_mt.sql
[java] 2022-07-07 11:34:56,527 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppc_data_uniqueid.sql
[java] 2022-07-07 11:34:56,544 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppc_data_uniqueid_mt.sql
[java] 2022-07-07 11:34:56,545 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppc_data_uniqueid.sql
[java] 2022-07-07 11:34:56,547 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppc_data_uniqueid_mt.sql
[java] 2022-07-07 11:34:56,548 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_aggregate_usage.sql
[java] 2022-07-07 11:34:56,551 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_aggregate_usage.sql
[java] 2022-07-07 11:34:56,552 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_aggregate_usage.sql
[java] 2022-07-07 11:34:56,568 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_aggregate_usage.sql
[java] 2022-07-07 11:34:56,569 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_aggregate_usage.sql
[java] 2022-07-07 11:34:56,573 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/SPPR_REBUILD_INDEXES.sql
[java] 2022-07-07 11:34:56,574 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_rebuild_indexes.sql
[java] 2022-07-07 11:34:56,575 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_rebuild_indexes.sql
[java] 2022-07-07 11:34:56,576 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_rebuild_indexes.sql
[java] 2022-07-07 11:34:56,577 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_rebuild_indexes.sql
[java] 2022-07-07 11:34:56,586 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_sys_getindextime.sql
[java] 2022-07-07 11:34:56,587 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_sys_getindextime.sql
[java] 2022-07-07 11:34:56,588 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_sys_getindextime.sql
[java] 2022-07-07 11:34:56,589 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_sys_getindextime.sql
[java] 2022-07-07 11:34:56,590 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_sys_getindextime.sql
[java] 2022-07-07 11:34:56,591 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_sys_reservequeueitem_b.sql
[java] 2022-07-07 11:34:56,592 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_sys_reservequeueitem_b.sql
[java] 2022-07-07 11:34:56,593 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_sys_reservequeueitem_b.sql
[java] 2022-07-07 11:34:56,594 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_sys_reservequeueitem_b.sql
[java] 2022-07-07 11:34:56,594 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_sys_reservequeueitem_b.sql
[java] 2022-07-07 11:34:56,597 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_sys_statusnodes_set.sql
[java] 2022-07-07 11:34:56,598 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_sys_statusnodes_set.sql
[java] 2022-07-07 11:34:56,599 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_sys_statusnodes_set.sql
[java] 2022-07-07 11:34:56,600 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_sys_statusnodes_set.sql
[java] 2022-07-07 11:34:56,601 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_sys_statusnodes_set.sql
[java] 2022-07-07 11:34:56,602 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_sys_updatescache_flush.sql
[java] 2022-07-07 11:34:56,603 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_sys_updatescache_flush.sql
[java] 2022-07-07 11:34:56,604 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_sys_updatescache_flush.sql
[java] 2022-07-07 11:34:56,605 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_sys_updatescache_flush.sql
[java] 2022-07-07 11:34:56,606 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_sys_updatescache_flush.sql
[java] 2022-07-07 11:34:56,607 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_sys_updatescache_gettime.sql
[java] 2022-07-07 11:34:56,608 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_sys_updatescache_gettime.sql
[java] 2022-07-07 11:34:56,609 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_sys_updatescache_gettime.sql
[java] 2022-07-07 11:34:56,610 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_sys_updatescache_gettime.sql
[java] 2022-07-07 11:34:56,610 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_sys_updatescache_gettime.sql
[java] 2022-07-07 11:34:56,614 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/db2zos/proc/sppr_defragment_table.sql
[java] 2022-07-07 11:34:56,614 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/proc/sppr_defragment_table.sql
[java] 2022-07-07 11:34:56,615 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/proc/sppr_defragment_table.sql
[java] 2022-07-07 11:34:56,616 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/proc/sppr_defragment_table.sql
[java] 2022-07-07 11:34:56,617 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/udb/proc/sppr_defragment_table.sql
[java] 2022-07-07 11:34:56,618 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/all/dataupdate/pr4_rule_vw-pzClassType-populate.sql
[java] 2022-07-07 11:34:56,651 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/postgres/dataupdate/pr4_rule_vw-pzClassType-populate.sql
[java] 2022-07-07 11:34:56,652 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/oracledate/dataupdate/pr4_rule_vw-pzClassType-populate.sql
[java] 2022-07-07 11:34:56,653 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/dataupdate/pr4_rule_vw-pzClassType-populate.sql
[java] 2022-07-07 11:34:56,653 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/all/dataupdate/pr4_rule_vw-pzRuleSetVersionMinorPatch-populate.sql
[java] 2022-07-07 11:34:56,654 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/mssql/dataupdate/pr4_rule_vw-pzRuleSetVersionMinorPatch-populate.sql
[java] 2022-07-07 11:35:00,255 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:00,256 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:00,257 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:00,257 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:00,312 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:00,467 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:00,471 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:00,501 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:00,552 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:00,555 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:00,584 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:00,594 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:00,602 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:00,613 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:00,634 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:00,638 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:00,641 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:00,666 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:00,671 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:00,698 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:18,582 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:18,811 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:18,812 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:18,812 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:18,839 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:18,845 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:18,847 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:18,851 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:18,861 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:18,865 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:18,871 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:18,874 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:18,877 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:18,880 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:18,883 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:18,886 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:18,888 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:18,897 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:18,900 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:18,905 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:24,954 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:24,955 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:24,955 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:24,956 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:24,973 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:24,979 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:24,981 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:24,985 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:24,993 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:24,996 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:25,000 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:25,003 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:25,006 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:25,009 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:25,012 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:25,014 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:25,017 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:25,031 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:25,035 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:25,041 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:40,537 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:40,538 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:40,538 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:40,538 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:40,555 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:40,562 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:40,564 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:40,567 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:40,577 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:40,579 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:40,591 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:40,594 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:40,597 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:40,600 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:40,605 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:40,607 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:40,609 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:40,618 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:40,621 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:40,625 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:49,152 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,163 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:49,163 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:49,164 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:49,201 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,207 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:49,209 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,212 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:49,218 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:49,221 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:49,223 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:49,226 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:49,228 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:49,231 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,235 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:49,237 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,241 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:49,243 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:49,247 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:49,514 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,514 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:49,514 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:49,515 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:49,532 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,537 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:49,540 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,542 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:49,555 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:49,560 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:49,565 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:49,569 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:49,573 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:49,576 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,589 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:49,592 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,600 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:49,604 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:49,609 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:49,856 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,856 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:49,857 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:49,857 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:49,874 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:49,879 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:49,881 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,883 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:49,888 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:49,891 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,894 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:49,919 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:49,922 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:49,924 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:49,927 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:49,929 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:49,931 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:49,935 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:49,948 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:49,952 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:50,156 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,157 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:50,157 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:50,164 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:50,185 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,190 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:50,192 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,194 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:50,200 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:50,203 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,205 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:50,208 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:50,213 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:50,215 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:50,217 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:50,221 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:50,223 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,227 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:50,230 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:50,242 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:50,495 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,495 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:50,496 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:50,496 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:50,514 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,519 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:50,522 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,524 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:50,530 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:50,533 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:50,542 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:50,545 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:50,548 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:50,550 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,554 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:50,556 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,561 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:50,564 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:50,567 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:50,740 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,740 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:50,741 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:50,741 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:50,758 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:50,763 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:50,765 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,767 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:50,773 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:50,776 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:50,778 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:50,781 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:50,783 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:50,785 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,788 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:50,790 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:50,794 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:50,796 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:50,811 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:51,125 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:51,125 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:51,125 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:51,126 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:51,143 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:51,149 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:51,151 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,153 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:51,179 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:51,181 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,184 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:51,190 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:51,194 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:51,196 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:51,200 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:51,201 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:51,203 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,208 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:51,212 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:51,215 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:51,425 ( install) INFO - Calling SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:51,425 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter){}
[java] 2022-07-07 11:35:51,425 ( install) INFO - Initializing properties with default values
[java] 2022-07-07 11:35:51,426 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2022-07-07 11:35:51,442 ( install) INFO - Exiting SchemaManager(Document, DatabasePlatform, SchemaManagerAdapter)
[java] 2022-07-07 11:35:51,447 ( install) INFO - Resolving URI "" / table.xsl
[java] 2022-07-07 11:35:51,449 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,451 ( install) INFO - Resolving URI "" / column.xsl
[java] 2022-07-07 11:35:51,456 ( install) INFO - Resolving URI "" / index.xsl
[java] 2022-07-07 11:35:51,458 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,462 ( install) INFO - Resolving URI "" / trigger.xsl
[java] 2022-07-07 11:35:51,464 ( install) INFO - Resolving URI "" / stored-proc.xsl
[java] 2022-07-07 11:35:51,467 ( install) INFO - Resolving URI "" / view.xsl
[java] 2022-07-07 11:35:51,469 ( install) INFO - Resolving URI "" / function.xsl
[java] 2022-07-07 11:35:51,472 ( install) INFO - Resolving URI "" / privilege.xsl
[java] 2022-07-07 11:35:51,474 ( install) INFO - Resolving URI "" / platform.xsl
[java] 2022-07-07 11:35:51,475 ( install) INFO - Resolving entity "null" / file:///usr/117230_Pega8.64/scripts/dynamic.ent
[java] 2022-07-07 11:35:51,480 ( install) INFO - Resolving URI "" / postgres/postgresType.xsl
[java] 2022-07-07 11:35:51,483 ( install) INFO - Resolving URI "" / common.xsl
[java] 2022-07-07 11:35:51,487 ( install) INFO - Resolving URI "" / prolog.xsl
[java] 2022-07-07 11:35:51,621 ( SchemaGenerator) INFO - ddlFilePath: /usr/117230_Pega8.64/schema/generated/postgres/install
[java] 2022-07-07 11:35:51,622 ( SchemaGenerator) INFO - stmtFilePath: /usr/117230_Pega8.64/schema/generated/postgres/install/statements
[java] 2022-07-07 11:35:51,622 ( SchemaGenerator) INFO - udfStmtFilePath: /usr/117230_Pega8.64/schema/generated/postgres/install/udfstatements
generate_install_ddl:
Apply DDL:
Apply DDL Inner:
[echo] using driver jar file: usr/share/java/postgresql-jdbc.jar
[java] 2022-07-07 11:35:53,862 ( SQLLoader) INFO - Starting logging to : 'logs/SQLinstaller.log'
[java] 2022-07-07 11:35:53,867 ( SQLLoader) INFO - --config=/tmp/PegaInstallTemp-07-July-2022-11.34.18/prbootstrap.properties||--profile=install.postgres||/usr/117230_Pega8.64/scripts/../schema/generated/postgres/install/statements||
[java] 2022-07-07 11:35:53,877 ( SQLLoaderInternal) INFO - Starting on /usr/117230_Pega8.64/schema/generated/postgres/install/statements
[java] 2022-07-07 11:35:53,901 ( ConnectionWrapper) INFO - Attempting to load profile "install.postgres":
[java] 2022-07-07 11:35:53,903 ( ConnectionWrapper) INFO - Type: postgres
[java] 2022-07-07 11:35:53,904 ( ConnectionWrapper) INFO - Class: org.postgresql.Driver
[java] 2022-07-07 11:35:53,906 ( ConnectionWrapper) INFO - URL: jdbc:postgresql://localhost:5432/pega
[java] 2022-07-07 11:35:53,908 ( ConnectionWrapper) INFO - User: pegadev
[java] 2022-07-07 11:35:53,909 ( ConnectionWrapper) INFO - JDBC Properties:
[java] Exception in thread "main" java.lang.IllegalArgumentException: Unable to load class: org.postgresql.Driver
[java] at com.pega.pegarules.install.ConnectionWrapper.get(ConnectionWrapper.java:331)
[java] at com.pega.pegarules.install.ConnectionWrapper.createStatement(ConnectionWrapper.java:350)
[java] at com.pega.pegarules.install.SQLLoaderInternal.getStatement(SQLLoaderInternal.java:190)
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:119)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:99)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:78)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:66)
[java] Caused by: java.lang.ClassNotFoundException: org.postgresql.Driver
[java] at java.net.URLClassLoader.findClass(URLClassLoader.java:387)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:418)
[java] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:352)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:351)
[java] at java.lang.Class.forName0(Native Method)
[java] at java.lang.Class.forName(Class.java:264)
[java] at com.pega.pegarules.install.ConnectionWrapper.get(ConnectionWrapper.java:329)
[java] ... 7 more
BUILD FAILED
/usr/117230_Pega8.64/scripts/setupDatabase.xml:465: The following error occurred while executing this line:
/usr/117230_Pega8.64/scripts/setupDatabase.xml:2347: Java returned: 1
Total time: 1 minute 37 seconds
Ant Process returned a non 0 value
Show Less
