i am unable to see case details after upgrading from 8.5.5 to 8.6.4
we see the follwing error in the logs
[8/16/22 15:00:15:842 EDT] 000000cd SystemOut O 2022-08-16 15:00:15,812 [ WebContainer : 6] [UserPortal] [
] [ SPC:01.01.01] (ternal.mgmt.StreamBuilderTools) ERROR pegauat.saifg.rbc.com|uapg2au10 192820330 - Problem appending
stream null
com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException
at com.pega.pegarules.priv.runtime.jsp.StreamBuilderBase.handleError(StreamBuilderBase.java:161) ~[prpublic.jar:?]
at com.pegarules.generated.html_section.ra_stream_casedetails_b0c9f537721d7a9609a0d98b81c045a5.execute(ra_stream_casedeta
ils_b0c9f537721d7a9609a0d98b81c045a5.java:176) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:786) ~[
prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.getStream(IncludeStreamRuntime.java:339) ~[p
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.emitIncludeStreamReference(IncludeStreamRunt
ime.java:255) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.emitIncludeStreamReference(AutoStreamRuntim
eImpl.java:433) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.emitIncludeStream(ContextPro
cessor.java:1434) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.executeSection(ContextProces
sor.java:1220) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.ContextProcessor.processSection(ContextProces
sor.java:1182) ~[prprivate-session.jar:?]
sor.java:1463) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.context.RuntimeContextTree.loadSection(RuntimeContext
Tree.java:515) ~[prprivate-session.jar:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.buildSection_6(ra_stre
am_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6642) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.sectionBodyIncludeInCe
ll_6(ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6648) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.pzLayoutBodyWrapper_4(
ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6627) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.pzLayout_4(ra_stream_p
ycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6703) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.simpleLayoutTemplateCe
ll_4(ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6854) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.simpleLayout_2(ra_stre
am_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6945) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemaininner_53b6196929af079b31fe4e18d073afb5.pzLayoutBody_2(ra_stre
am_pycasemaininner_53b6196929af079b31fe4e18d073afb5.java:6616) ~[?:?]
Exception in : RULE-HTML-SECTION RBC-SPC-WORK-CMTMANUALCASECREATION CASEDETAILS #20210728T140210.174 GMT
Caused by: com.pega.pegarules.pub.generator.UnresolvedAssemblyError: Exception in : RULE-HTML-SECTION RBC-SPC-WORK-CMTMANUALCASECREATION CASEDETAILS #20210728T140210.174 GMT
at com.pegarules.generated.html_section.ra_stream_casedetails_b0c9f537721d7a9609a0d98b81c045a5.execute(ra_stream_casedetails_b0c9f537721d7a9609a0d98b81c045a5.java:136) ~[?:?]
***Edited by Moderator Marije to add Support Case Details;***
