Rules forms doesnt not open
Rules set version or any application UI rules belong to app ruleset doesnt open.Just shows blank screen,
On tracing the rule open i see errror on openUI defaults activity
** Invalid expression or reference: No candidates found [possible function name, ruleset/version or number of parameter problem] for Rule-Utility-Function in ruleset list Lib(Pega-RULES:DateTime).CurrentDateTime()
Below error logged
2016-03-31 16:48:59,333 [ WebContainer : 6] [ Developer] [ MLRCORE:01.01.02] (eForm.Rule_Obj_Property.Stream) ERROR ftwdsdbg2g31.r1-core.r1.aig.net|XX.XX.XXX.XX RanjiMLR - Error in JSP execution com.pega.pegarules.pub.generator.UnresolvedAssemblyError: Invalid expression or reference: No candidates found [possible function name, ruleset/version or number of parameter problem] for Rule-Utility-Function in ruleset list <null> Lib(Pega-RULES:DateTime).CurrentDateTime() at
2016-03-31 16:41:45,296 [nectorThreadPool : 1] [ STANDARD] [ ] (internal.library.LibLibraryDef) ERROR - Library Pega-UIEngine.Harness has inconsistent Rule-Utility-Function key / implementation issues. These may be the result of merging the Function from another ruleset.
Planning to delete the pegrules marker file and restart the server ? Any other suggestion to resolve this error ?
