Jabil
Last activity: 25 Apr 2016 15:12 EDT
Unable to calculate codeset version from database: Cannot create PoolableConnectionFactory
I'm getting "Unable to calculate codeset version from database: Cannot create PoolableConnectionFactory" after upgrading my system to Pega 7.2.
Not sure if the issue is related to the value for pzcodesetversion on table rules.pr_engineclasses, what should be the value? or if this is related to something else.
Oscar
It is related to the pr_engineclasses table where we calculate the codeset version (e.g., for 7.2, the value is 07-10-23). But most likely you issue is something else (the error is just a victim), please attach your complete startup log.
Jabil
This is the log
Apr 25, 2016 12:44:32 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
19830421:
19830421:
Apr 25, 2016 12:44:32 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
19830421: Engine classes schema: rules
19830421: Assembled classes schema: rules
19830421: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
Apr 25, 2016 12:45:10 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
This is the log
19830421:
19830421:
19830421: PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create PoolableConnectionFactory (The TCP/IP connection to the host corrdcpegadb01, port 1433 has failed. Error: "null. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".)
Apr 25, 2016 12:45:10 PM com.pega.pegarules.internal.bootstrap.PRMiniLoader
19830421: Will load phase 2 bootstrap from Pega-EngineCode:
Hi Oscar,
Are you using Split schema?
Which application / web server you are using?
Jabil
Pega 7.2 on Apache Tomcat
Hi Oscar,
Are you using Split-schema or single schema configuration for this setup?
Can you please share context.xml from Tomcat/config?
Jabil
Context.xml content
<Environment name="prconfig/database/databases/PegaRULES/defaultSchema" value="rules" type="java.lang.String" />
<Environment name="prconfig/database/databases/PegaDATA/defaultSchema" value="data" type="java.lang.String" />
<Resource name="jdbc/PegaRULES"
auth="Container"
type="javax.sql.DataSource"
driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://corrdcpegadb01:1433;databaseName=prpc_sbx_devjaws40;
SelectMethod=cursor;SendStringParametersAsUnicode=false"
username="prpc_sbx_devjaws40"
password="************"
maxActive="100"
maxIdle="30"
maxWait="10000"
removeAbandonedTimeout="60"
logAbandoned="true"
Here in context.xml, we can see that your PegaRULES and PegaDATA schema names are, rules and data respectively.
Can you please try using data against username in context.xml? You Data schema password against password field.
You need to restart the tomcat post this change.
A modified context.xml would look like:
auth="Container"
username="data"
password=
maxActive="100"
maxIdle="30"
maxWait="10000"
auth="Container"
username="data"
password=
maxActive="100"
maxIdle="30"
maxWait="10000"
logAbandoned="true"
Jabil
OK the error related to EngineCodeVersion is gone, now I get:
SEVERE: Unable to connect to database. Will only use properties from file.
org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (The TCP/IP connection to the host corrdcpegadb01, port 1433 has failed. Error: "null. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".)
Jabil
It complains on connecting to Database.
Can you please see if you are able to ping database server ?
Also, check firewall etc
PEG
Could you restart the SQL Server Service and try?
Jabil
SQL Server restarted but still same issue with same error message
Can you try as mentioned in following:
Jabil
It works now!
It looks like the DNS server name was not recognized so I changed the server name to its IP in the context.xml file and now it works.
Thanks for the quick support.
Oscar
