Morgan Stanley
Last activity: 10 May 2016 3:53 EDT
How to determine the codeset version
Hi
I have a few questions on the codeset:
1. Where do we usually set the codeset
2. How to determine the codeset version the system is currenly running on
3. How do i know which codeset is related to which Pega Version
Regards
Avinash
Morgan Stanley
Our infra team has figured it out what the issue is...
While resetting the instance they have hardcoded the engineclasses codeset to 07-10-13 version in setupDatabase.properties file.
Now that they have reset the instance again by removing them.
Updated: 5 May 2016 4:49 EDT
Hi Avinash,
Usually while running Pega platform, you can find two codesets and with specific versions.
1. Pega-Engine codeset - Contains Pega shipped java classes.
2. Customer codeset - To import third party or customer specific jar files.
You can't set the Pega-Engine codeset, as it is unique for every shipped Pega platform version.
Eg:- 07-10-15 for Pega717, 07-10-17 for Pega718 & 07-10-19 for Pega719.
Customer codeset will be set to 06-01-01 by default and this you can update while importing any external jars into PRPC database.
You can determine pega-engine codeset version of the current system from the system startup logs, at prbootstrap configuration. (something like below, this is for 719 version).
============ PegaRULES Bootstrap Configuration ============
Date: Wed May 04 07:55:41 IST 2016
Java Version: Oracle Corporation 1.7.0_71
Configuration: file:/C:/Pega-Instances/Pega-719/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 07-10-19
ASM Version: 554097615
Database: Microsoft SQL Server 11.00.2100
Driver: Microsoft JDBC Driver 4.0 for SQL Server 4.0.2206.100
Active CodeSets: pega-enginecode:07-10-19 at (latest patch)
Hi Avinash,
customer:06-01-01 at (latest patch)
=============== End Bootstrap Configuration ===============
You can also query pr_engineclasses Db table on your PRPC DB to check the pega-engine codeset versions, it can contain multiple pega-engine codeset versions if it's an upgraded system.
Hope this information helps, let me know if you have any specific queries.
BR//
Harish
Morgan Stanley
Our tomcat server is not starting after an upgrade of our Horizontal. The platform remains same, we are on Pega 7.2 version.
Below is the error log from our server:
05-May-2016 01:58:34.002 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI.
05-May-2016 01:58:34.002 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: pegarules
05-May-2016 01:58:34.002 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: pegarules
05-May-2016 01:58:34.018 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
05-May-2016 01:58:34.049 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Using latest detected engine version:(EngineCodeSetVersion= 07-10-23). To specify a different version, use the setting com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode in prbootstrap.properties.
05-May-2016 01:58:34.065 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:07-10-23
05-May-2016 01:58:34.096 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader.
05-May-2016 01:58:34.112 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. ============================= Failed to bootstrap PegaRULES =============================
05-May-2016 01:58:34.127 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Could not load the java class 'com/pega/pegarules/internal/bootstrap/phase2/PRBootstrapImpl.class' from the database table 'pegarules.pr_engineclasses'
05-May-2016 01:58:34.127 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. This is usually due to an empty 'pegarules.pr_engineclasses' table, or possibly it does not contain the configured codeset version.
05-May-2016 01:58:34.127 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. In this run the prbootstrap.properties specified 'pega-enginecode:07-10-23', checking database...
05-May-2016 01:58:34.299 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. 'pegarules.pr_engineclasses' contains a total of 113128 classes, searching for available codesets...
05-May-2016 01:58:34.330 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Codeset |Version
05-May-2016 01:58:34.346 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. passbook |07-13-01
05-May-2016 01:58:34.346 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pega-enginecode |07-10-13
05-May-2016 01:58:34.362 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pega-enginecode |07-10-23
05-May-2016 01:58:34.362 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pegamkt |07-21-01
05-May-2016 01:58:34.362 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pegamkt3rdparty |01-01-01
05-May-2016 01:58:34.362 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pegamkt_kpi_parser |07-13-01
05-May-2016 01:58:34.377 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. progallconstraint |07-01-01
05-May-2016 01:58:34.377 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. puma |06-02-01
05-May-2016 01:58:34.377 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. pushnotification |07-13-01
05-May-2016 01:58:34.377 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. segmentvisualisation |07-13-01
05-May-2016 01:58:34.393 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader.
05-May-2016 01:58:34.393 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Subsequent exceptions relating to class not being found are all related to this root cause...
05-May-2016 01:58:34.393 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Check to make sure the database is correctly configured and that the codeset version specified was correct and is present in that database.
05-May-2016 01:58:34.393 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. =========================================================================================
C:\Tomcat8032\apache-tomcat-8.0.32\webapps\prweb\WEB-INF\lib\boot\prbootphase2.jar (The system cannot find the path specified)
Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
05-May-2016 01:58:34.424 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
Date: Thu May 05 01:58:34 PDT 2016
Java Version: Oracle Corporation 1.8.0_45
Configuration: file:/C:/Tomcat8032/apache-tomcat-8.0.32/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 07-10-23
Database: DB2/LINUXX8664 SQL10055
Driver: IBM Data Server Driver for JDBC and SQLJ 4.19.26
Unable to use given database configuration
Unable to locate classes on filesystem
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
05-May-2016 01:58:34.455 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:720)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:662)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4812)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5255)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
Any insight in this regard would be of great help..
PEG
PL
Do a clean restart. Might be your pega temp directory has different PegaRULES_Extract_Marker.txt file.
Could you share more detail on this?
PEG
PL
By any chance have you upgraded your system? If yes, share the upgrade logs as well.
Morgan Stanley
No, we have a clean install of our platform version 7.2
Yesterday we had updated our horizontal layer Pega Marketing to GA version and ever since the upgrade the appserver is not starting.
But, I don't think the horizontal upgrade has anything to do with the codeset version..
The log just says the below:
One difference i observed is that the pr_engineclasses table in the db does not have 07-10-23 code set version for the PRBootstrapImpl class but other machines which are on 7.2 have 07-10-23 against PRBootstrapImpl class.
select * from pegarules.pr_engineclasses where pzclass like '%PRBootstrapImpl%';
Have you modified .properties files, such as prbootstrap.properties etc?
From the log we can see that it is finding the pr_engineclasses table and that there is a Pega-EngineCode:07-10-23 like there should be. It just doesn't seem to find the PRBootstrapImpl class in that codeset in the table.
You mention that you upgraded the horizontals. What did you change? I would look at your PegaRULES datasource in context.xml and make sure you have all of the connection properties set. Your url should look like this
jdbc:db2://localhost:50000/dbName:fullyMaterializeLobData=true;fullyMaterializeInputStreams=true;progressiveStreaming=2;useJDBC4ColumnNameAndLabelSemantics=2;
I missed the note where you said this was a fresh install. If this is a fresh install you should only have one pega-enginecode codeset version but it looks like you have 2. We need to look at where this 07-10-13 codeset version came from. Since you have already opened an SR it will be worked under that.
Morgan Stanley
Do you have any idea of the location from where Pega picks up the version of the pega-enginecode codeset.
Updated: 9 May 2016 4:34 EDT
Hi Avinash,
PRBootstrap class is responsible for querying the engine classes DB table to get the list of pega-engine codesets from the specified datasource.
This class gets the list of Pega-engine codesets and determines the highest code-set.
The above process can be overridden through prbootstrap.properties file, you can set the respective pega-engine codeset value based on your version. This is only used incase of any discrepancies on upgraded systems and not recommended for new installations.
# Active CodeSets
# Code sets (other than Pega-EngineCode) are now specified via Data-Admin-System-Settings, but you can override database settings with settings from the file.
# For Pega-EngineCode latest code set version available in the system will be used, but you can override this behavior with settings from the file.
#Example:
com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode=07-10-23 (this value represents 7.2 Pega-engine codeset)
#<code set version> should be of format dd-dd-dd, d for digit
Morgan Stanley
Thanks Harish.
One of our pega instance is on 7.2 version.. However, the engine codeset version which it picks up is 07-10-13 and to my surprise the records in pr_engineclasses also does not have 07-10-23 codeset version records.
This is a new instance and was not upgraded from any earlier version.
Not sure from where the 13 version was getting picked up from.
Any thoughts?
Virtusa IT Consulting
AE
you can run following query to get codeset version
select pzcodeset from pr_engineclasses;
Morgan Stanley
Thanks Habeeb.
I think you mean select pzcodesetversion from pr_engineclasses;
The above query returns only the version 07-10-13 for pega-enginecode codebase which is really concerning.
The version is supposed to be 07-10-23
AE
Can you give a try for below query?
select pzcodesetversion from pr_engineclasses where pzcodesetversion='07-10-23'
I think below entry is being returned from database
Also please check prbootstrap.properties file in below location in tomcat
C:\apache-tomcat-7.0.32\webapps\prweb\WEB-INF\classes
From the error logs I believe you have single schema configuration?
Morgan Stanley
AE
Please confirm have you deployed prweb.war file from 7.1.6 media or 7.2 media file?
AE
Avinash Haridasu can you try redeploying of prweb.war from 7.1.6 media file keeping the same datasource details?
Morgan Stanley
When i deployed the 7.2 version of prweb i get the below exception.. I had reverted to my existing version.
09-May-2016 04:33:01.969 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Loading bootstrap properties from /prbootstrap.properties
09-May-2016 04:33:01.984 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
09-May-2016 04:33:02.000 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
09-May-2016 04:33:02.000 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Bootstrap datatables schema: null
09-May-2016 04:33:03.969 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Archive version [0]
09-May-2016 04:33:03.969 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine schema defined in allclasses: null
09-May-2016 04:33:03.969 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI.
09-May-2016 04:33:03.984 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI.
09-May-2016 04:33:03.984 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: null
09-May-2016 04:33:03.984 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: null
09-May-2016 04:33:03.984 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
09-May-2016 04:33:04.063 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: DB2 SQL Error: SQLCODE=-204, SQLSTATE=42704, SQLERRMC=PEGADATA.PR_ENGINECLASSES, DRIVER=4.19.26
09-May-2016 04:33:04.078 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
09-May-2016 04:33:04.109 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: DB2 SQL Error: SQLCODE=-204, SQLSTATE=42704, SQLERRMC=PEGADATA.PR_ENGINECLASSES, DRIVER=4.19.26
09-May-2016 04:33:04.172 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
Date: Mon May 09 04:33:04 PDT 2016
Pega-EngineCode:
PEG
It looks it's not able to find the schema name. Can you give the schema name and try?
Are you using single schema or split schema database configuration?
I believe, you are using Split-schema, can you please check on RULES n DATA schema bindings at server level?
AE
Avinash Haridasu You need to check 'context.xml' file for rules and data schema bindings.
Hi Avinash,
I feel 7.2 rule-base installation was somehow got messed up. Ideally we must be seeing more than 10k+ records in pr_engineclasses under 07-10-23 codeset for a valid 7.2 system.
Either it has to be an installation issue or somehow your data source is pointing to a wrong one. It's better to have this investigated on the SR.
Morgan Stanley
