Unable to find Spring classes from Pega database
We are trying to set up shared library for Pega 7.2 in Websphere 8.x. We created the shared library with custom jars and have referenced the shared library in the classloader. We have updated the DSS with the shared library path. We are running into issues when trying to test application that uses the custom jar in the shared location. Its able to find the custom java class but failing to find a spring class which is in the pega database(pr_engineclasses). Below is the stack trace. Any thoughts on why it is not able to find the class from database?
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:466)
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.runActivities(ServiceAPI.java:1896)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1277)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1015)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:848)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.handleRequest(JMSListener.java:1267)
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.runOnce(JMSListener.java:709)
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListenerServant.invoke(JMSListenerServant.java:112)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor75.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:246)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRJMSListener.callEngine(PRJMSListener.java:208)
at com.pega.pegarules.session.internal.engineinterface.etier.mdb.PRJMSListener.onMessage(PRJMSListener.java:130)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.etier.mdb.PRJMSListenerBoot.onMessage(PRJMSListenerBoot.java:91)
at com.ibm.ejs.jms.listener.MDBWrapper$PriviledgedOnMessage.run(MDBWrapper.java:309)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:63)
at com.ibm.ejs.jms.listener.MDBWrapper.callOnMessage(MDBWrapper.java:266)
at com.ibm.ejs.jms.listener.MDBWrapper.onMessage(MDBWrapper.java:235)
at com.ibm.mq.jms.MQSession$FacadeMessageListener.onMessage(MQSession.java:147)
at com.ibm.msg.client.jms.internal.JmsSessionImpl.run(JmsSessionImpl.java:2846)
at com.ibm.mq.jms.MQSession.run(MQSession.java:862)
at com.ibm.ejs.jms.JMSSessionHandle.run(JMSSessionHandle.java:1058)
at com.ibm.ejs.jms.listener.ServerSession.connectionConsumerOnMessage(ServerSession.java:1090)
at com.ibm.ejs.jms.listener.ServerSession.onMessage(ServerSession.java:760)
at com.ibm.ejs.jms.listener.ServerSession.dispatch(ServerSession.java:726)
at com.ibm.ejs.jms.listener.ServerSessionDispatcher.dispatch(ServerSessionDispatcher.java:47)
at com.ibm.ejs.container.MDBWrapper.onMessage(MDBWrapper.java:98)
at com.ibm.ejs.container.MDBWrapper.onMessage(MDBWrapper.java:135)
at com.ibm.ejs.jms.listener.ServerSession.run(ServerSession.java:581)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1691)
Caused by:
java.lang.NoClassDefFoundError: org.springframework.context.support.ClassPathXmlApplicationContext
at com.fepoc.eob.service.PersistenceServiceFactory.<clinit>(PersistenceServiceFactory.java:14)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:236)
at java.lang.Class.forNameImpl(Native Method)
at java.lang.Class.forName(Class.java:179)
at com.pegarules.generated.activity.ra_action_invoke_d0ac00606040955e7e296725cd7cc4fa.step4_circum0(ra_action_invoke_d0ac00606040955e7e296725cd7cc4fa.java:572)
at com.pegarules.generated.activity.ra_action_invoke_d0ac00606040955e7e296725cd7cc4fa.perform(ra_action_invoke_d0ac00606040955e7e296725cd7cc4fa.java:120)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3510)
at com.pegarules.generated.activity.ra_action_starteobmessaging_cb9041c926490d34d22744a0819841a9.step6_circum0(ra_action_starteobmessaging_cb9041c926490d34d22744a0819841a9.java:698)
rteobmessaging_cb9041c926490d34d22744a0819841a9.perform(ra_action_starteobmessaging_cb9041c926490d34d22744a0819841a9.java:168)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
... 57 more
Caused by:
java.lang.ClassNotFoundException: org.springframework.context.support.ClassPathXmlApplicationContext
at java.net.URLClassLoader.findClass(URLClassLoader.java:434)
at com.ibm.ws.bootstrap.ExtClassLoader.findClass(ExtClassLoader.java:204)
at java.lang.ClassLoader.loadClassHelper(ClassLoader.java:688)
at java.lang.ClassLoader.loadClass(ClassLoader.java:667)
at com.ibm.ws.bootstrap.ExtClassLoader.loadClass(ExtClassLoader.java:119)
at java.lang.ClassLoader.loadClass(ClassLoader.java:650)
at com.ibm.ws.classloader.ProtectionClassLoader.loadClass(ProtectionClassLoader.java:62)
at com.ibm.ws.classloader.ProtectionClassLoader.loadClass(ProtectionClassLoader.java:58)
at com.ibm.ws.classloader.CompoundClassLoader.loadClass(CompoundClassLoader.java:566)
... 69 more
***Updated by Moderator: Marissa to add SR details that didn't migrate over***
