ITC InfoTech India Ltd,
Upgrade from 6.1 SP2 to 7.1.7 - Could not reserve enough space for object heap
Issue while upgrading from 6.1 SP2 to Pega 7.1.7
Approach : Single schema to Split schema
Issue faced
We are facing the below issue while Executing the PEGA Upgrade Wizard (IUA) from a Windows Server 2008:
Run Update Wizard:
[java] Could not create the Java virtual machine.
[java] Error occurred during initialization of VM
[java] Could not reserve enough space for object heap
BUILD FAILED
F:\PRPC717\PRPC717_fullversion\pegaGuiInstallerTemp\build.xml:83: The following error occurred while executing this line:
F:\PRPC717\PRPC717_fullversion\scripts\setupDatabase.xml:319: The following error occurred while executing this line:
F:\PRPC717\PRPC717_fullversion\scripts\setupDatabase.xml:2284: Java returned: 1
Total time: 234 minutes 15 seconds
Below are the Application details :
Current PEGA environment : PEGA 6.1 SP2
Upgrade version : PEGA 7.1.7, 64 bit JVM
Database: DB2/AIX64
Split schema approach : Yes
Rule schema name : RXPQ
Data schema name : RXRF
4 GB RAM
Enough disk space (PEGA recommendation is > 6 GB)
JVM version: 1.6.0_06 (build 1.6.0_06-b02)
Solution tried but failed
Updated the memory in the machine to Min – 512 MB and Max – 1536 MB which is also mentioned as a Resolution per PDN link below. https://pdn.pega.com/support-articles/could-not-reserve-enough-space-object-heap
