    AIG
PRPC_Setup.jar- Could not create the Java virtual machine-[java] Could not reserve enough space for object heap
Issue Description: PRPC rules upgrade from 6.1 SP2 to 7.1.7 failing at the below mentioned state.
Run Update Wizard:
[java] Could not create the Java virtual machine.
[java] Error occurred during initialization of VM
BUILD FAILED
F:\PRPC717\PRPC717_fullversion\pegaGuiInstallerTemp0\build.xml:83: The following error occurred while executing this line:
F:\PRPC717\PRPC717_fullversion\scripts\setupDatabase.xml:319: The following error occurred while executing this line:
F:\PRPC717\PRPC717_fullversion\scripts\setupDatabase.xml:2284: Java returned: 1
Operating environment :
- JRE used to run is VM Name: Java HotSpot(TM) Client VM(build 1.6.0_06-b02) - - 32 bit
- OS: Windows Server 2008, version: 6.2, Architecture: x86
- Database: DB2/AIX64 SQL0907B
- JDBC Driver: IBM DB2 JDBC Universal Driver Architecture 3.64.114
- JRE version : 32 bit
- RAM : Initially it was 4 GB and later it was upgraded to 12 GB
- Split schema : Yes
Description of failed attempts :
Attempt 1: Normal command prompt, with local admin user ID with elevated access and no specific heap settings to JVM, system memory as 4 GB RAM
Attempt 2: Power shell command prompt with downgraded access to user with all privileges, specific heap settings as Min : 512 MB, Max : 1024 MB and system memory as 4 GB RAM
Attempt 3: Normal command prompt, admin user id access with no heap settings and 4 GB RAM
Attempt 4: Normal command prompt, System memory upgraded from 4 GB to 12 GB, set heap size params as Min : 512 MB, Max : 1024 MB and ran again but on 32 bit jvm
Below is the command has been used to initiate upgrade wizard :
                java -Xms512m -Xmx1024m -XX:PermSize=64m -XX:MaxPermSize=384m -jar PRPC_Setup.jar
Question -
with same configuration few(other) application's upgrade was successful without issue, why?
is it must to have 64bit jdk (upgrade execution only)?
what is recommonded jvm parameter to get success results ?
