British Gas
Last activity: 8 Mar 2016 7:19 EST
Unable to login as Marketing Analyst
I'm trying to do exercises for Intro to Pega Marketing but unable to login into VM as Marketing Analyst. I can login as Admistrator and DSMUser but NOT as Marketing Analyst, please can you help?
Regards
Neil,
Thanks a lot for your post.
Please make sure you started the "Practicing What you Learned" part with the "Environment Setup" step.
After this you will be able to sign in as MarketingAnalyst@IntroPegaMk
Marco.
British Gas
Hi Marco,
What do you mean by started the "Practicing What you Learned" part with the "Environment Setup" step. Sorry , I couldn't find this step in Environment set up pdf. Please can you explain this.
Regards
Neil,
Sorry for not being clear.
Hope the two images below help:
- Practicing What You Learned
- Environment Setup
Marco.
British Gas
Sorry if I'm not clear , when I try to login as MarketingAnalyst after starting "Practising what you've learned" I get below message It is somehow not recognizing username and password and I've tried that many times so far:
"The information you entered was not recognized. "
Wynand,
Did you complete the first step, by importing the jar?
Marco.
British Gas
Yes, I did complete first step because I was able to login as Admin. The issue is when I try to login as Marketing Analyst its not letting me in. This situation is preventing me to proceed with exercises. Can U please advise what else I can try?
Regards
Ai4Process
Maybe an error occurred when importing the jar, could you give it another try?
Damien
Wynand,
We reached the point that it is better to take the conversation offline.
Hence we sent you a private message.
Since you have not responded we are not sure you got it.
Please feel free to reach out to us by sending an email to [email protected]
Marco.
