Questions on Introduction to Integration lesson
What are best practices with regards to handling interface changes for connectors? (Choose Two)
Avoid regenerating the interface, instead try to apply changes manually
Use the generated classes and properties directly in your application
Use the Resource Settings feature for environmental specific variables
Correct!
Use a separate ruleset for each generated interface
Correct!
Does the lesson somewhere indicate that using a separate ruleset for each generated interface is a best practice, or explain why it is a best practice? Not sure I saw that.
