Quiz question on Validating User Input lesson
The following question from the quiz:
Validating user input against a range of values is best accomplished: (Choose One)
- Setting the “Min/Max chars” value on the form control
- Using a Validate rule
- Using the “Display and Validation” settings on the property
- Setting the “Min/Max chars” values on the property
In order to pass the quiz the user needs to select Using a Validate rule as the only possible answer.
However, at least in my opinion, Using the “Display and Validation” settings on the property may be a better option depending on the context:
- If the range of possible values depends on the property's context, then a Validate rule is the best option. For example, Financial Plan might have different ranges of possible values depending on other Input, e.g. Customer Status (Gold, Silver, etc..)
- If the property has an invariable range of possible values, e.g. Gender, I think it makes more sense to define it at the Property lelevl using Display and Validation settings.
Does it make sense?
Juan Cortines
