Quiz question - Server Side Validation
I have doubt in the following question
Which of the following requirements should not be handled in an edit validate rule? (Choose One)
Check if the telephone number contains the country code
Check if the unit price is not negative
Make sure the address is not empty
Check if the zip code conforms to the United States postal code standard
Correct!
Edit Validate rule is an overkill for this purpose
If Edit Validate rule is an overkill for this purpose, then what is recommended to make sure the address is not empty ?
Sudarsan M
