Broken queue
How to read a broken queue , I have a queue which has 1000 repeating events in it , how do u find which record has generated an error.
Thank
Thank
To see list of broken queue items, from Developer portal click on Pega--> Process and Rules --> Tools --> Work Admin --> Broken Queue Items.
Here select your Queue class and click execute. An list would be displayed with all broken items for that queue.
Vamshi
thanks Vamsi , after that if there are 1000 records, how to coreleate which record(s) are broken in that queue
In addition, you can also look into same details from SMA.
From SMA --> Click on Corresponding Node --> Agent Management --> System Queue Management --> Click on the Radio Button for "Broken-Process" and click on details.
Vamshi
All 1000 are broken. If you want see all the list items, then toggle the filter as highlighted
