DB Error - No more data to read from socket during 7.1.7 installation
The installation fails most of the times at this step due to DB error as given below - java.sql.SQLRecoverableException: No more data to read from socket
We had done this before in the same environment but now it fails consistently 4 times at the step V6 archive - Started import of application bundle component pr4_rule_07.10.01.zip (58 of 83)...out 83 zip
1) Any inputs to the avoid this error or there any time out settings to be set for jdbc explicitly in the scripts?
Environment: Oracle Proprietary information hidden
ojdbc7.jar
[java] 2015-07-17 11:47:58,482 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Operation Status: Completed import of application bundle component pr4_rule_OtherTables_07.10.01.zip (57 of 83).
[java] 2015-07-17 11:47:58,482 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Imported 57 of 83 archives (68.67%) 18:53 minutes remaining
[java] 2015-07-17 11:47:58,485 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Operation Status: Started import of application bundle component pr4_rule_07.10.01.zip (58 of 83)...
[java] 2015-07-17 11:47:58,487 [ main] [ ] [ ] (y.internal.PRRuleMgmtUtilsImpl) INFO - pr4_rule_07.10.01.zip is v6 Archive
[java] Caught SQLException while reading prprivate.jar!com/pega/pegarules/deploy/internal/util/OptimizationCandidateListImpl$CandidateImpl.class
[java] java.sql.SQLRecoverableException: No more data to read from socket
[java] at oracle.jdbc.driver.T4CMAREngineStream.unmarshalUB1(T4CMAREngineStream.java:453)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:390)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:566)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:215)
[java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:58)
[java] at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:943)
[java] at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:929)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1034)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3820)
[java] at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3867)
[java] at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1502)
[java] at com.pega.pegarules.configdbcp.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:99)
Tried the resume.sh script to start from where the installation left but that too failed as below
2) Is this resume.sh script supposed to start from where the last installation was left or failed due to timeout or network issues etc?
3) Should we always do the manual cleanup and restart from beginining everytime it fails
4) Are there any out of box scripts to wipe out the data from the split schema tables or anything generated under the schema/generated/oracledate that should be run to wipe the data or objects?
[java] 2015-07-17 07:53:02,449 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Skipping archive 'pr4_rule_OtherTables_07.10.01.zip' (to resume on 'pr4_rule_07.10.01.zip')
[java] 2015-07-17 07:53:02,449 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - pr4_rule_OtherTables_07.10.01.zip : Imported already
[java] 2015-07-17 07:53:02,449 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Resuming import on 'pr4_rule_07.10.01.zip')
[java] 2015-07-17 07:53:02,449 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Moving resume step to 'pr4_rule_07.10.01.zip')
[java] 2015-07-17 07:53:02,457 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Operation Status: Started import of application bundle component pr4_rule_07.10.01.zip (58 of 83)...
[java] 2015-07-17 07:53:02,458 [ main] [ ] [ ] (y.internal.PRRuleMgmtUtilsImpl) INFO - pr4_rule_07.10.01.zip is v6 Archive
[java] 2015-07-17 07:53:10,551 [ main] [ ] [ ] (rnal.archive.ApplicationBundle) INFO - Importing 58 of 83 : pr4_rule_07.10.01.zip (Upgrade Mode)
[java] 2015-07-17 07:53:10,585 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - PegaRULES Embedded Edition 7.10 (ML7)
[java] 2015-07-17 07:53:10,585 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - coreAssemblyCached_717_644: 2014-11-26 14.24 EST
[java] 2015-07-17 07:53:10,585 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - Now starting the PegaRULES Embedded Environment...
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - JVM Information:
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Vendor: Oracle Corporation, JVM version: 1.7.0_79
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - VM Name: Java HotSpot(TM) 64-Bit Server VM(build 1.7.0_79-b15)
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Host OS Information:
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - OS: Linux, version: 2.6.18-348.18.1.el5
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Architecture: amd64
[java] 2015-07-17 07:53:10,609 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 7.10 (ML7)
[java] 2015-07-17 07:54:57,996 [0758v01.cloud.ge.com] [ ] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Setting EnabledGlobalDeclarativeCachePreLoad to NONE as minimal startup is enabled.
[java] 2015-07-17 07:54:59,815 [0758v01.cloud.ge.com] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: pwnld0758v01.cloud.ge.com
[java] com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
[java] at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:392)
[java] at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1905)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:657)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
[java] at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngineImpl(EngineImpl.java:240)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:119)
[java] at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:112)
[java] at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.ensureEngineStarted(ParUtilsImpl.java:273)
[java] at com.pega.pegarules.deploy.external.util.DeploymentRunner.<init>(DeploymentRunner.java:76)
[java] at com.pega.pegarules.deploy.external.util.DeploymentUtility.runMethodWithRequestor(DeploymentUtility.java:86)
[java] at com.pega.pegarules.deploy.external.util.DeploymentUtility.runMethodWithRequestor(DeploymentUtility.java:77)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.runWithRequestor(ImportImpl.java:2747)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.importArchive(ImportImpl.java:1280)
[java] at com.pega.pegarules.deploy.internal.archive.ApplicationBundle.doImport(ApplicationBundle.java:1524)
[java] at com.pega.pegarules.deploy.internal.archive.ApplicationBundle.doImport(ApplicationBundle.java:645)
[java] at com.pega.pegarules.deploy.external.util.Application.deployApplication(Application.java:278)
[java] at com.pega.pegarules.deploy.external.util.Application.main(Application.java:459)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:606)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.context.PRSecurityException: Unable to construct authorization core due to authorization failure
[java] at com.pega.pegarules.session.internal.authorization.SessionAuthorization.<init>(SessionAuthorization.java:245)
[java] at com.pega.pegarules.session.internal.mgmt.PRRequestorBase.allocateSessionAuthorization(PRRequestorBase.java:537)
[java] at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.allocateSessionAuthorization(PRRequestorImpl.java:2009)
[java] at com.pega.pegarules.session.internal.authorization.Authorization.reset(Authorization.java:432)
[java] at com.pega.pegarules.session.internal.authorization.Authorization.reset(Authorization.java:381)
[java] at com.pega.pegarules.session.internal.authorization.Authorization.onBeforeThreadUse(Authorization.java:1624)
[java] at com.pega.pegarules.session.internal.mgmt.base.ThreadPassivation.configureThreadImpl(ThreadPassivation.java:316)
[java] at com.pega.pegarules.session.internal.mgmt.PRThreadBase.configureThread(PRThreadBase.java:176)
[java] at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.<init>(PRThreadImpl.java:131)
[java] at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.acquire(PRThreadImpl.java:146)
[java] at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:175)
[java] at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:162)
[java] at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:158)
[java] at com.pega.pegarules.session.internal.mgmt.base.RequestorPassivation.configureRequestorImpl(RequestorPassivation.java:477)
[java] at com.pega.pegarules.session.internal.mgmt.PRRequestorBase.configureRequestor(PRRequestorBase.java:480)
[java] at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.<init>(PRRequestorImpl.java:299)
[java] at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.acquire(PRRequestorImpl.java:323)
[java] at com.pega.pegarules.session.internal.mgmt.base.MultiThreadRequestorFactory.acquire(MultiThreadRequestorFactory.java:61)
[java] at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.createRequestorImpl(NodeRequestorMgt.java:1476)
[java] at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.createRequestorImpl(NodeRequestorMgt.java:1456)
[java] at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:773)
[java] at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:371)
[java] ... 26 more
[java] Caused by: com.pega.pegarules.pub.context.InvalidConfigurationException: Data-Admin-Requestor instance "prpc!BATCH" not found
[java] From: (B7A221B135982DD76221C1E77DC4F5CB7)
[java] at com.pega.pegarules.session.internal.authorization.SessionAuthorization.reset(SessionAuthorization.java:446)
[java] at com.pega.pegarules.session.internal.authorization.SessionAuthorization.<init>(SessionAuthorization.java:241)
[java] ... 47 more
could you please check the database table mapping for history classes.
If it is PR_HISTORY then update to PC_HISTORY_WORK & share your observations
