TR
Last activity: 14 Mar 2015 7:59 EDT
NonexistentTableException during the split schema insallation of PRPC 7.1.7
I've faced the exception below during a split schema installation of PRPC 7.1.7 on a Windows-Tomcat-Oracle stack. Tried both manual installation and automatic insallation but both failed with the same exception.
Anyone faced the same exception before or know the solution?
Kind Regards,
Emin
com.pega.pegarules.pub.database.NonexistentTableException: Database-NonexistentTable APP_PEGA_COLL_DATA.pr_assign PegaDATA
infosys
PDN says : This exception is thrown when PegaRULES configuration points to a database table that does not exist.
Can you do a select of the table and check if the user id of the installation has access to it. Alternatively you can grant access (from sys user) to the pr_assign table for the current user and then re-try.
TR
Hello Amit,
Thanks for the reply, I've checked that and the table APP_PEGA_COLL_DATA.pr_assign exists and the user APP_PEGA_COLL_DATA has access to it. I can select and desc the table without any issues but still facing the exception com.pega.pegarules.pub.database.NonexistentTableException: Database-NonexistentTable APP_PEGA_COLL_DATA.pr_assign
Kind Regards,
Emin
infosys
You can check if the table is "well-formed"
This exception direcly inherits from ConfigurationException for which details are as below :-
This exception is thrown if there is bad configuration. This might be due to a database table with missing columns, or invalid information in a Rule used by the database (such as Rule-Obj-Class, Data-Admin-DB-Name, or Data-Admin-DB-Table).
Axiom Technology Group
so for example, it can also be due to an incorrectly defined schema in the Data-Admin-DB-Table.
TR
I've another PRPC 7.17 instance. I've compared the pr_assign table with APP_PEGA_COLL_DATA.pr_assign and they are identical. I've dropped the data and rules user and re-created the schemas and tried again with both automatic and manual installations but faced the same exception each time :(
Kind Regards,
Emin
Hi Emin, is the deployment using a user that has the select_catalog_role role? It grants the ability to perform meta-data queries about the database structure such as column names and their size & type. Also, please review all privileges and roles required on pages 21 & 22 of the guide, and verify.
https://pdn.pega.com/documents/pega-717-installation-guide-for-apache-tomcat-on-oracle
If this doesn't solve your problem, can you provide the full stacktrace?
TR
Hello John,
The deployment user has dba rights so no privilege issues. You can see the full stacktrace below.
Kind Regards,
Emin
java] 2015-03-11 10:59:18,675 [ main] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
[java] 11.Mar.2015 10:59:18 com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.PRException: A problem occurred.
[java] From: (unknown)
[java] at com.pega.pegarules.deploy.external.util.Application.main(Application.java:464)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
Hello John,
Kind Regards,
Emin
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.PRException: Unable to complete import of Application Bundle.
[java] at com.pega.pegarules.deploy.internal.archive.ApplicationBundle.doImport(ApplicationBundle.java:1538)
[java] at com.pega.pegarules.deploy.internal.archive.ApplicationBundle.doImport(ApplicationBundle.java:645)
[java] at com.pega.pegarules.deploy.external.util.Application.deployApplication(Application.java:278)
[java] at com.pega.pegarules.deploy.external.util.Application.main(Application.java:459)
[java] ... 9 more
[java] Caused by: com.pega.pegarules.pub.database.NonexistentTableException: Database-NonexistentTable APP_PEGA_COLL_DATA.pr_assign PegaDATA
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.figureOutSchema(TableInformationMapImpl.java:821)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.lookupTableInfo(TableInformationMapImpl.java:473)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.get(TableInformationMapImpl.java:384)
[java] at com.pega.pegarules.data.internal.access.TableInformationMapImpl.get(TableInformationMapImpl.java:346)
[java] at com.pega.pegarules.data.internal.dictionary.ClassMapImpl.readExternalPropertyDefinitions(ClassMapImpl.java:2506)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.seedClassMapWithProperties(ImportImpl.java:2767)
[java] at com.pega.pegarules.deploy.internal.util.ImportImpl.bootstrapPegaRULES(ImportImpl.java:559)
[java] at com.pega.pegarules.deploy.internal.archive.ApplicationBundle.doImport(ApplicationBundle.java:1338)
[java] ... 12 more
[java] 11.Mar.2015 10:59:18 com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java] ... 9 more
[java] ... 12 more
[java] Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:271)
[java] Caused by: com.pega.pegarules.pub.PRException: A problem occurred.
[java] ... 1 more
[java] ... 9 more
[java] ... 12 more
[java] 2015-03-11 10:59:18,725 [ main] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Cache Serialization to database enabled
[java] 2015-03-11 10:59:18,734 [ main] [ ] [ ] ( external.util.Application) ERROR - A problem occurred.
[java] com.pega.pegarules.pub.PRException: Unable to complete import of Application Bundle.
[java] ... 12 more
The root cause was a mismatch of the character encoding between the server performing the deployment and the database configuration. Please refer to the deployment guides for proper environment configuration.
