Pega 7.1.7 Installation Failure
Hi ,
Trying to install Pega 7.1.7 using JBOSS EAP 6.3 Application Server & DB2 LUW
During Pega installation getting the below error .
[java] Jul 06, 2015 10:48:40 AM com.pega.pegarules.install.SQLLoader writeMessage
[java] WARNING: Failed to execute SQL in file udb_udf07300.sql
[java] WARNING: Statement: CREATE FUNCTION PEGARULES.pr_read_from_stream
[java] (property varchar(255), insKey varchar(512), stream blob(5m))
[java] returns varchar(1000)
[java] language java
[java] parameter style java
[java] no sql
[java] fenced threadsafe
[java] deterministic
[java] no external action
[java] external name
[java] 'PEGARULES.PRREADSTREAM:com.pega.pegarules.data.udf.directstreamreader.DirectStreamReaderDB2LUW.get'
[java] com.ibm.db2.jcc.am.mo: DB2 SQL Error: SQLCODE=-454, SQLSTATE=42723, SQLERRMC=PEGARULES.PR_READ_FROM_STREAM, DRIVER=4.7.85
Tried with dropping and recreating of schema , but getting the same issue.
