TATA Consultancy Services LTD.
Last activity: 9 Jun 2015 21:04 EDT
Exercise Accessing External Systems : Reusing Data Transform for Background Check
Hi ,
In the exercise -Accessing External Systems : Reusing Data Transform for Background Check- , we are reusing the BackgroundCheck section that is imported. But in exercise it is asked to add the fileds - Bankruptcy,CreditReport etc those are returned from data transform - to the flow and then delete the sections cretaed by it once we reuse the imported section. Why we are doing it so ? If we need to reuse a section -BackgroundCheck- that is imported , cant we use it directly instead of doing extra work of creating sections and delting the old ones. Please clarify.
In above screen print I have deleted the sections created after adding fields to the form using configure form option.
