pzCssincludee missing
Any idea on below exception
Getting below exception after Clearing the temp,index and cache file
Could not find a rule when appending a stream
com.pega.pegarules.pub.generator.RuleNotFoundException: Failed to find instance @baseclass.pzCSSInclude
when pega genaraters customer code for UI elements they will be stored as pzCSSInclude_<<HASHCODE>>.
When you deleted the temp and cache folders, system not able to find it.. close the browser session and try it out. It should work..
If doesnt work even then try to restart the server to prepopulate some of the cache.
